11-09-2017 12:41
11-09-2017 12:41
Does anyone knows if the bugs for the blaze and the Galaxy S8 has been fix yet? I'm not able to see the notifications in the blaze.
Best Answer11-13-2017 04:56
11-13-2017 04:56
You are welcome @Paulette89, if you need anything else, let me know. And for your to know, I have heard that the Samsung Galaxy S8/S8+ work perfectly with the Fitbit Ionic. ![]()
Happy stepping! ![]()
11-10-2017 07:06
11-10-2017 07:06
A warm welcome to the Community @Paulette89. If you are having issues with your Blaze notifications, I recommend taking a look at this post and follow the instructions provided in My Tracker isn't receiving notifications (Android App).
I hope this helps, let me know the outcome. ![]()
11-10-2017 07:27
11-10-2017 07:27
Hello @AlejandraFitbit I have tried all of that and nothing. I really like the blaze but this feature is not working, I might try to change to the Ionic to see if the problem is only with the blaze. Thanks for your help!
If you hear anything else that could work let me know.
11-13-2017 04:56
11-13-2017 04:56
11-13-2017 08:16
11-13-2017 08:16
Thanks @AlejandraFitbit I already retuned the blaze I will be buying the ionic. Hope it works!
Thanks for you help! 😁👌
11-16-2017 16:23
11-16-2017 16:23
I was told last week from Fitbit Customer Service that they are working hard to fix the no notifications with S8and S8+. Still not working on mine......
Best Answer11-16-2017 18:03
11-16-2017 18:03
Hi @rosemarieilovey they told me the same thing but I returned it and Im going to try my luck with the ionic and see if the notifications work. I'll let you know if it works.
