06-09-2016 02:37
06-09-2016 02:37
Best Answer06-09-2016 04:26
06-09-2016 04:26
Best Answer06-09-2016 04:29
06-09-2016 04:29
@Billu what do you mean by not perfect?
There is no information given as to what is wrong?
Best Answer06-09-2016 04:40
06-09-2016 04:40
Best Answer06-09-2016 05:34
06-09-2016 05:34
05:42
09:28
06-09-2016
05:42
09:28
Hey there @Billu. Welcome to the Community! 🙂
I would recommend two things in your case. The first one, just to avoid anything being stuck or not working fine in your tracker, restart it by pressing the left and lower right buttons together for 10-15 secs. and also, you can change the sensitivity from your settings. For that, go into your tracker settings on fitbit.com (the little gear icon at the top right corner of your screen) after that, click on the little picture of your tracker on the drop down menu. Here scroll to the bottom and on "Sleep Tracking" you can change the settings to normal or sensitive and then save the changes and sync your tracker.
See if this makes any difference and if you still need more help, let us know!
Best Answer06-09-2016 05:45
06-09-2016 05:45
05:50
09:27
06-09-2016
05:50
09:27
I know! I've also seen you around lately @SunsetRunner. Team work is the clue to success so hopefully I will see you around more often! 😄
Have a great day you both!
Best Answer06-09-2016 06:03
06-09-2016 06:03
I was just curious where else you've seen me posting? Because I have never seen you on any discussions or threads. ![]()
Have a good day,
Kai
"The roots of education may be bitter, but the fruit is sweet."
-Aristotle
