10-08-2017 15:30
10-08-2017 15:30
Hi
This morning I went to sync my blaze and it goes through the process but wouldn’t sync everything. I tried turning off Bluetooth and on again. I also turned the watch off. Any other ideas to help please? It’s an Android phone I’m trying to sync it with
Best Answer10-08-2017 17:54
10-08-2017 17:54
I had to turn off the WiFi and do the same steps you did to get my S8 Plus to sync. Hope that helps.
Best Answer10-08-2017 21:48
10-09-2017 05:11
10-09-2017 05:11
It's great to see you here @Kirbee, thanks for troubleshooting this by yourself, @Rich_Laue and @Flame3503 for stopping by.
If your tracker isn't syncing, I recommend taking a look at the Having trouble syncing? post and follow the instructions provided there. After those steps, your tracker should sync properly.
Let me know the outcome. ![]()
