03-28-2017 14:32
03-28-2017 14:32
Hi my fitbit blaze stopped charging. It will turn on , while on the charger. It will get the overheat signal after about 5 mins of charging. I have tried [restarting, buying a new charger, different plus, outlets]
Nothing will get it past the red on the battery. Also the battery icon does not show up.
Thank you ,
03-28-2017 15:47
03-28-2017 15:47
Hey there @Kingosteps! Thanks for the details that you've mentioned. I've shared your information with Customer Support and they should get back to you within the following days.
Thanks for your understanding.
03-28-2017 15:47
03-28-2017 15:47
04-23-2017 12:22
04-23-2017 12:22
Hi mine is doing the same & I have only had it since Christmas! Could you please ask customer support to contact me aswell @SilviaFitbit?
04-23-2017 12:35
04-23-2017 12:35
Try contact.fitbit.com for a quicker tesponse @Lolapops1
04-24-2017 05:40
04-24-2017 05:40
Hey there @Lolapops1! I've shared your post with Customer Support, they will reply to you within the following days.
Thanks for the advice @Rich_Laue.
Hope this helps.
08-20-2017 18:16
08-20-2017 18:16
I'm having the same problem
08-21-2017 01:38
08-21-2017 01:38
@Fitgofit, then i suggest you do the same and contact fitbit.
08-22-2017 17:01
08-22-2017 17:01
Is there a solution to this yet? Mine is also overheating, will not charge, AND the left button isn't functioning. Customer support so far told me to try charging it somewhere cooler (!?) Honestly, I tried 3 outlets, my laptop & even plugged it into my car charger holding it up to the air condition vent to keep it cool! Waiting for a different resolution from customer service. They are usually very good!!
08-24-2017 11:12
08-24-2017 11:12
It's great to have you here @mbcarbery! Thanks for the details that you've mentioned. Customer Support will always provide you with some troubleshoot before providing you with anything else.
Also, I've sent you a PM with further instructions.
08-28-2017
06:39
07:36
SilviaFitbit
08-28-2017
06:39
07:36
SilviaFitbit
My Fitbit Blaze will not charge and it over heats while it is plugged in, when I plug it in the Fitbit logo shows the charge meter is never displayed
Moderator edit: format
08-28-2017 07:39
08-28-2017 07:39
Hey there @Kevinpoppa! I've shared your post with Customer Support, they should be able to follow up with you within the following days.
Hope this helps!
10-08-2017 08:04
10-08-2017 08:04
Is there a solution to this problem yet? Mine is doing the same thing ( have had it since Christmas) I have tried cleaning the battery contacts, restarting it, and have tried 3 different chargers in 3 different outlets. Sometimes it will start to charge but won't keep it, even had it show it was almost fully charged but an hour later when I went to get it, the overheating icon and a dead blaze once again. Going on 3 days with this problem.
10-09-2017 10:52
10-09-2017 10:52
I emailed FitBit support- they had me mail my Blaze to them, and sent me a brand new one!
They were great!
10-10-2017 17:44 - edited 10-10-2017 17:45
Hey there @Lellie! Thanks for the troubleshoot and details that you've mentioned. If your Blaze is showing the overheating icon, the recommendation will be to restart the tracker and change your environment.
In this case, I've share your post with Customer Support as it seems your Blaze isn't responding properly to the procedures you've followed.
Thanks for sharing your experience @mbcarbery!
Keep me posted.
09-04-2018 01:15
09-04-2018 01:15
hi @SilviaFitbit mine too doing the same can you help me. tnx
09-04-2018 10:21
09-04-2018 10:21
The advice @SilviaFitbit will give is to contact Fitbit.
The link is also found in the top right menu and will be your best choice as pointed out in Silvia's last post
09-04-2018 16:20
09-04-2018 16:20
A warm welcome to the Community @juntenio. In this case, I've shared your post with our Customer Support team. They will continue assisting you on this matter.
Thanks for your advice @Rich_Laue.
Hope this helps! Keep me posted.
