08-30-2017 00:58
08-30-2017 00:58
My tracker first synchronized on 25th July suddenly stopped sync since 26 th Aug the green light at the back of the tracker is also not on
Best Answer08-30-2017 05:50
08-30-2017 05:50
Hi there @SunsetRunner. Great to see you in the Forums! 🙂
I'm sorry you're having problems getting your Blaze to sync properly...
If you have not tried it, I would recommend restarting your tracker. You can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot and after that, see if it syncs without a problem after that.
Let me know how it goes or if you need more help with this!
Best Answer08-30-2017 07:36
08-30-2017 07:36
