03-25-2017 03:51 - last edited on 09-09-2020 09:49 by MatthewFitbit
I've been using my Charge 2 since xmas but recently (in the last two weeks) it has stopped auto tracking my exercise. I haven't changed any of the settings to auto recognise exercise. I read on one of these threads to reset the Charge 2 three times in a row by pressing the button whilst charging, did that last weekend and it recognised my daily walks on Mon and Tues but by Wed it stopped working again. This morning I did a 1hr bootcamp and although it records that I did 49 Active Mins at that time, the Exercise tile doesn't show anything. Any ideas!?
03-25-2017 11:18
03-25-2017 11:18
I've only had one problem with this, when it's set to the standard 15 min for a walk, move it to 14 or 16 and it works perfectly and even syncs data that has previously
been missed.
03-25-2017 11:09
03-25-2017 11:09
Hi @Wyndola,
For the auto-track, the reboot should have gotten it going. You may want to look into initiating the exercise mode on the tracker manually. If you forget, you can always go into the fitbit.com dashboard, under Log Activity, and manually add the exercise afterwards.
03-25-2017 11:18
03-25-2017 11:18
been missed.
03-25-2017 18:54
03-25-2017 18:54
I'm wondering what exercise boot camp falls under?
What could help us to disable any auto exercises you normally will not be doing
03-25-2017 21:07
03-25-2017 21:07
03-25-2017 22:49 - edited 03-25-2017 22:51
I'm not sure how helpful it will be but here is the autotrack FAQ
http://help.fitbit.com/articles/en_US/Help_article/1933/#exercises
It does imply that if the movement was continuous enough for the 10 or 15, I'm not sure, minutes some event should have been recognized.
03-28-2017 05:06
03-28-2017 05:06
Thanks KevP - Cross fingers, changing the minutes down to 14 instead of 15 seems to have fixed it! It recognised the two walks I did today and yesterday. Will post back to let you know if it stays working.
Rich_Laue - I think there is something buggy about the exercise tile. Even though it's now auto tracking and shows 20 active mins, it is still showing only 1 day out of 5 as completed (yesterday). Yesterday I only did 19 active mins so logically it should count today's 20 mins as day 2. Rather annoying as it's not motivating at all but I'm glad it's auto tracking again.
03-28-2017 06:59
03-28-2017 06:59
04-04-2017 04:40
04-04-2017 04:40
Brilliant - seems to have stayed fixed!! Thank So kev!
04-04-2017 09:21
04-04-2017 09:21
05-26-2017 04:16
05-26-2017 04:16
Same problem, i haven't had my fitbit for 30 days, if i wanted to enter info then i would not have upgraded to this new fitbit. I called service dept yesterday, so far nothing, i am unhappy with company and device.
05-26-2017 16:50
05-26-2017 16:50
Im nit sure if i understand you @Voidedlime, or who your replying to? Your post doesnt look as if it fits here?
01-25-2018 19:55
01-25-2018 19:55
Got my Charge 2 for Christmas—it has never auto-tracked exercise. I’ve tried several things suggested on Google to no success. Can anyone help me?
01-26-2018 04:00
01-26-2018 04:00
01-28-2018 09:10
01-28-2018 09:10
01-28-2018 11:22
01-28-2018 11:22
09-07-2018 04:18
09-07-2018 04:18
I changed the auto recognise time from 15” to 14”, then 16”, but my Charge 2 still did not recognise the 20” brisk walk I did yesterday in my Exercise history, even though it was recorded as 20 active minutes.
09-07-2018 04:21
09-07-2018 04:21
I find if I do this the total number of steps alters inexplicably. Is manual exercise logging only meant for logging after exercise when you didn’t wear your watch?
09-17-2018 10:48
09-17-2018 10:48
My Charge 2 also stopped automatically recognizing my daily 2 hr. rides about a week ago. I can get it to recognize them if I manually select "bike" before I start, but I could have done that with just using my phone without even having a FitBit. Besides, I ride the same trail every day and don't need to see my route on a map. I'm mostly interested in the length of time each ride took and my heart rate tracking.
I did try the trick of changing the trigger time to something other than the default 15 minutes. Others responded that they immediately saw exercise that they had already completed. That didn't happen to me, even after manually forcing another re-sync. I've even reset my Fitbit a few times with no improvement.
12-26-2018 18:53
12-26-2018 18:53
Thank you
This worked for me with my Charge 3 not auto logging activity
