10-07-2016 16:59 - last edited on 09-09-2020 10:26 by MatthewFitbit
01-17-2017 11:31
01-17-2017 11:31
I followed all of the steps suggested to restart my Charge 2, checked all setting in the app and on my iPhone, I disconnected my Fitbit from Bluetooth, deleted the Fitbit app and reinstalled everything but did not receive any pin to restart (just reloaded everything as it had been) and when I scroll through the notifications on my actual charge, the icon states that notifications are off even though everything I can see on menus have it allowed/turned on! Please help!
01-17-2017 12:36
01-17-2017 12:36
01-18-2017 11:18
01-18-2017 11:18
I had followed all the steps but it still wasnt working, then I came across a help article that provided me with the final step which was to make sure that the notification setting was actually turned on on the fitbit itself! Pressed the button for a few seconds and Im now receiving all notifications!!
The Blaze, Charge 2, and Surge models have a Notification setting on the tracker. To verify that it's on:
01-19-2017 10:27
01-19-2017 10:27
Thank you, This worked!!!
01-20-2017 01:55
01-20-2017 01:55
This has not worked for me.. my tracker receives calls but not txt message, really confused
01-23-2017 10:22
01-23-2017 10:22
I did all of this and I still am not getting texts or call alerts on my charge 2!
01-23-2017 16:03
01-23-2017 16:03
Have you held the button on the side to make sure your notifications are on and not off. That's what was wrong with mine after trying everything else.
01-23-2017 16:09 - last edited on 05-21-2019 17:00 by EdsonFitbit
The issue I was having took place a while back before we were able to turn notifications on and off from the device.
01-25-2017 19:44
01-25-2017 19:44
MY device is paired but still does not send notifications. The indicator in settings is also turned on for my iPhone 6 plus
01-26-2017 18:21
01-26-2017 18:21
I have I phone 6
From the forum -I repeated what someone else tried
I removed the app, reloading the app and no luck
Re sync the Charger 2
no luck
Any other ideas
01-30-2017 17:41
01-30-2017 17:41
SOLVED! So even though your app may say notifications on, your Fitbit itself may be set to do not disturb!! Hold the button on the side for three seconds and tell them them back on!
02-02-2017 00:37
02-02-2017 00:37
"- If you have Fitbit Blaze, Fitbit Charge 2, or Fitbit Surge, make sure your Notifications are turned on:
For Charge 2, from the clock screen, press and hold the button to make sure Notifications is set to On. Keep in mind notifications must be turned on to receive reminders to move throughout the day."
THIS is what I needed to do... make sure that you can see this when clicking the button on your Fitbit. If not, open the app, go to account - menu items - then make sure that the notifications is checked.
Even though I had notifications turned on in the app, they were disabled on my device. I didn't know this because I chose to not have the notifications menu item on my device.
02-02-2017 00:41
02-02-2017 00:41
There is a aerting in the iphones notifacation center that slso needs to be enabled.
02-02-2017 00:42
02-02-2017 00:42
Make sure you can see notifications when clicking through the device. If not, open the app > account > select your device > menu items... make sure notifications is checked. Re sync the device and click through and make sure notifications are on.
My app said they were on, but the device one was disabled and I wasn't seeing it. This fixed my problem!
02-02-2017 07:16
02-02-2017 07:16
I recently spent quite a while on the phone with Fitbit trouleshooting this same problem. Finally, they gave up and said I would receive an email. Here's the email:
Thanks for letting us know about your notifications. Our engineers are aware of the problem and are working to resolve it as quickly as possible.
We're sorry for any inconvenience it's caused. We appreciate your patience and look forward to getting you back on track.
Please let us know if there's anything we may do to assist you in the meantime.
What does this actually mean? Anyone else having this problem?
02-06-2017 04:11
02-06-2017 04:11
Please help I have Iphohne 6 plus, I have set it up correctly as far as I can tell, the only thing that doesn't work is call and text alerts, I have tried everyhting I know can you please help ?
02-06-2017 07:01
02-06-2017 07:01
Had the same problem over the weekend @KathrynEC
Turn off your iphone - hold right button until slide switch appears to turn off.
power back on by pressing the same button until the apple logo comes up.
Go to preferences/bluetooth and forget your charge 2 by touching the circle i/forget
navigate to the app store and download/install latest fitbit app from updates.
Launch the fitbit app on your iphone, after a quick clean up it should find your charge 2 again.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
02-07-2017 12:42 - edited 02-07-2017 12:51
After reading pages and pages of tips that did not work, finally found the one tip that solved my problem. Once I turned on notifications from my Charge 2 tracker, I started getting call and text notifications again.
The Charge 2 model has a Notification setting on the tracker. To verify that it's on: from the clock screen, press and hold the button and notification status will display.
02-07-2017 16:52
02-07-2017 16:52
02-09-2017 09:10
02-09-2017 09:10
Thank you, it's working now 🙂
