05-16-2017
10:54
10:58
05-16-2017
10:54
10:58
Hi there @Br2dive. Welcome to the Fitbit Family! 😄
In order to have your Charge 2 to restart, follow these instructions:
Let me know if you need anything else!
05-16-2017
17:28
09:27
FerdinandFitbit
05-16-2017
17:28
09:27
FerdinandFitbit
I have a charge 2, I just needed to put it on charge and hold the button on the side that changes modes for 4 seconds, thanks for your help!
Best Regards,
Brian Williams
Moderator edit: Removed personal information
09:29
10:57
05-17-2017
09:29
10:57
Oh, I see @Br2dive... Since you posted in the Flex board I assumed you were using a Fitbit Flex but I'm glad to hear you got your tracker to restart.
Anything else you may need, let me know!
I'll be moving your post to the Charge 2 board for categorization purposes.
I restarted the Fitbit but nothing it still has the same steps on it. What Now
Best Answer@pgenevrino you haven't mentioned the problem, but a restart is exactly that. It restarts the tracker, it does not change any data displayed.
I have a charge 2 and I can not get it to restart using this method at all. What else can I do?
Best AnswerMy charge 2 gives me too many active minutes and does not go back to 0, at the start of the day or after i have restarted it twice. talked to service and he said to call back if it did not work. any other ideas?
