03-04-2018 22:39 - last edited on 09-08-2020 18:54 by MatthewFitbit
I understand from this forum that the Charge 2 underestimating distance is a common problem but I had assumed the watch would sync with the app or take note of my manual adjustments and learn to improve accuracy. In other words, when I track a walk using the app, which uses GPS to track the distance, why doesn't the watch learn from this and adjust its stride length calculations? Same for when I adjust the distance manually. I just went for a short walk using both the app and the watch. App gives me 2.27km and watch says 1.64km.
03-05-2018 04:21 - edited 02-08-2024 06:38
Welcome to the Fitbit Community @SarahBart, I'm happy to have a new member around!
There are a few differences between Charge 2's connected GPS and using the Fitbit App's GPS to track your workout, they include:
1. Connected GPS runs help improve the accuracy of your Cardio Fitness Score. Click here for more details.
2. You are also able to see your workout metrics on the device in real-time during your workout with Connected GPS.
3. If you track one or more runs using Connected GPS, the Fitbit App evaluates the data and automatically updates your running stride length.
4. Connected GPS supports intervals and biking workouts; while MobileRun does not.
As you may know, Fitbit trackers calculate distance by multiplying your walking steps by your walking stride length and multiplying your running steps by your running stride length. By default, we calculate your stride length using your height and gender.
If you've already tracked one or more activities with the connected GPS, we evaluate that data to automatically update your running stride length. For best results, run at a comfortable pace for at least 10 minutes.
If your distance measurement seems inaccurate after double checking the above information, follow the steps below to calculate your stride length and then add it to your Fitbit account.
Your running stride can be calculated the same way if you run instead of walk.
To adjust your stride lengths using the Fitbit app, tap or click the Account icon and find the Stride Length setting.
03-06-2018 04:31
03-06-2018 04:31
Thanks. That’s useful information.
03-06-2018 05:47 - edited 03-06-2018 05:49
Thanks for getting back @SarahBart! Working with the GPS sensors in your phone, MobileRun calculates distance, elevation, and pace for your walk, run, or hike. When the activity is done and you sync your tracker, you'll find all the data and a GPS map of your route in your exercise history.
If you wear your tracker while using MobileRun, the steps, active minutes, and calories burned that you see on your Fitbit dashboard come from the tracker. Otherwise your phone is used to calculate this data. During the workout you can view your elapsed distance, time, and average pace as well as use the music controls in the Fitbit app.
On the other hand, Fitbit Blaze and Fitbit Charge 2 work with the sensors on your nearby phone to track GPS data (known as "connected" GPS). You can also check the article "How do I use exercise apps and modes on my Fitbit device? to get a detailed information about tracking your exercises with Charge 2.
To allow the Fitbit app to use your phone's GPS:
After you complete a GPS activity and sync your device, the activity is saved to your exercise history in the Fitbit app. To find details on your route map that might be hard to see on your phone's screen, look at the map on a computer instead. To do so, log into fitbit.com. At the top of the dashboard, click Log > Activities to see your activity log (known as your exercise history in the Fitbit app). You can expand any workout to see more details.
Hope this helps a little more!
01-24-2019 05:50
01-24-2019 05:50
I have gone through everything listed regarding GPS but my Fitbit simply wont track and show my route when I am out with my phone in my pocket. When I am at home on WiFi it works! It was working last week but this week not and as far as I am aware nothing has changed. What am I missing? Thanks.
