12-02-2016
07:35
10:26
12-02-2016
07:35
10:26
Experiencing the same problem. I'd like to wear it on my left wrist with the adjusting button showing up on the hand side of my wrist as opposed to the elbow side. Problem illustrated in attached photo. I've tried switching both the dominant hand and preferred wrist settings, but doesn't change anything. Ideas? Thanks! - Bill
Moderator edit: Subject for clarify.
12-04-2016 10:07
12-04-2016 10:07
Nope, won't work. I wear mine on the left wrist, but I have the button facing away from the wrist instead of towards it. I think there is a Feature Suggestion request on changing that - you may want to vote for that feature.
12-04-2016 05:11
12-04-2016 05:11
@bmitchfit Unfortunately, there is not a way to change the orientation of the face.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
12-04-2016 10:07
12-04-2016 10:07
12-17-2016 18:14
12-17-2016 18:14
Indeed! I was very surprised that I could not flip the orientation. Thank you for posting this image. I hope a future update will allow for this. Otherwise amazing device...
12-19-2016 11:14
12-19-2016 11:14
Can you swap the two band halves?
12-19-2016 11:55 - edited 12-19-2016 11:58
@Jimbolaya64 I can.
Here is where to vote for the screen rotation https://community.fitbit.com/t5/Feature-Suggestions/Ability-to-Rotate-Charge-2-Display/idi-p/1673072
12-19-2016 14:55
12-19-2016 14:55
Wouldn't swapping the band halves effectively flip the display?
12-19-2016 14:57 - edited 12-19-2016 20:59
Not really, it will turn the housing along with the display upside down. People want the ability to put the button on the right, witch is what switching the bands does, without the display being upside down.
See @bmitchfit post above
12-19-2016 16:44
12-19-2016 16:44
02-09-2017 12:09 - edited 02-09-2017 12:10
I found this to be a deal breaker and am returning the Charge 2 I recently bought because of it.
Wouldn't say this is solved more like can't or won't be solved
02-09-2017 13:52
02-09-2017 13:52
What i find interesting that the Blaze on the left arm should have the button on the left side. This is because the thumb is the best finger to press the button with.
A typical watch that needs to be wound by necessity needs to be on the hand side, or right. Sonce most people are right handed the Charge2 is set up properly to be worn on the left arm.
Now while wearing a wa5ch on the right arm, the Charge 2 button will be on the yrong side.
02-28-2017 06:02
02-28-2017 06:02
So what is this for?
03-10-2017 09:05
03-10-2017 09:05
I thought the same thing. Possibly makes a difference in how steps are measured. Same thing for handedness. A person likely swings their dominant hand for more activities.
Or or it could be a feature they meant to build (screen rotation) but ran out of time. Been there.
03-10-2017 10:15
03-10-2017 10:15
I think it might be a little deceptive.
The older trackers it simply was dominant - nondominant
The newer simply phrase it differently since many user had problems understanding dominant.
So Fitbit has set up two questions
What are do you normally use during the day?
What are is your Fitbit on?
For me I use my left arm to eat and write, but 90+ of everything else it is the right arm I use first.
Personal I think it would be nice if the screen flipped for the watch to be worn on the right arm, currently the button on the left is for wearing in the left arm so the stronger thumb can press it.
06-10-2017 19:00
06-10-2017 19:00
No it doesn't. The button always stays on the left according to fitbit customer service.
06-23-2017 18:27
06-23-2017 18:27
It drives me nuts because this is such a simple little bit of coding, but neglecting it is **ahem**ing for full- and part-time lefties, and people with motor control difficulties.
I periodically get gangliom cysts in my left wrist (I guess I use my left arm and shoulder more for strength-based things, so there's more strain). This makes wearing the fitbit on the left excruciating (plus it wont exactly fit under/over a brace), and I simply cannot (painlessly) move my wrist to hit the stupid freaking button when it's on the left side of my right wrist.
Somehow, the display feels assymmetrical, too-- it just doesn't sit right on the right wrist with the button on the left.
07-23-2017 12:17
07-23-2017 12:17
Nope, that will not flip the screen display.
12-10-2017 07:18
12-10-2017 07:18
You can’t adjust display on your wrist.
this is such a silly failure that I will return it.
A so intelligent watch not able to adapt display orientation: is it a joke?
02-14-2018 16:42
02-14-2018 16:42
I am flabbergasted at this design choice. Every watch I've ever worn had the buttons toward the fingers when worn on the left arm, including digital watches with multiple buttons (so it's not a winding issue) - it's just the norm. Even the cheap fitness tracker knock-off I have did it right. It makes me lose faith in humanity a little bit.
02-14-2018 20:08
02-14-2018 20:08
Have you voted @Philomorph, your mostly preaching to the choir when you post here. Personally I find it a lot more natural to press the button with the thumb and then to fidget with the finger while on the right side. You need the thumb and the two fingers to stabilize the clock anyway, having the button in the middle of the side makes this an unnatural movement.
