10-29-2018
11:44
15:03
10-29-2018
11:44
15:03
Can you sync with Samsung health? I have downloaded fit health but nothing is working.
10-30-2018 19:44
10-30-2018 19:44
@AmyLoy Welcome to the Fitbit Community.
I'm happy to respond your question about syncing with Samsung health. Currently, there is no option to link Fitbit with Samsung Health. For more information please visit this post. If there is any change, it will be communicated as soon as possible.
You can find the list of compatible apps currently available to link with Fitbit here.
If you have any other question, please don't hesitate to contact us again.
Best Answer10-30-2018 19:44
10-30-2018 19:44
Best Answer02-02-2019 14:18
02-02-2019 14:18
Yes you can sync Fitbit data with Samsung Health, at least on Android you can do it with the app called 'Health Sync'.
02-09-2019 05:04
02-09-2019 05:04
that was very helpful thank you.
02-12-2019 13:34
02-12-2019 13:34
@Renze @simosh Welcome and thank you for visiting the Fitbit Community.
There might be some ways to sync Fitbit with apps like Samsung Health, however if the app is not part of the list of apps supported by Fitbit we won't be able to recommend it as we can't guarantee that it will work as intended.
Keep on stepping.
02-16-2019 20:16
02-16-2019 20:16
Why after all these years does fitbit refuse to let us sync with Samsung health? To be very honest if I knew this before hand I wouldn't of bought the versa. Now that I've done research I'm still within my return limit I almost feel like doing so. Kinda ridiculous.
02-19-2019 12:45
02-19-2019 12:45
@H4rtl3ss Welcome to the Fitbit Community.
Thanks for your feedback. At the moment, there is no information about linking Fitbit with Samsung Health.
Hope to see you in the Community more often.
Best Answer04-12-2019 08:10
04-12-2019 08:10
I'm not a representative but this may be a Samsung issue not a Fitbit problem. Samsung sells it's own watch and that watch competes with Fitbit.
04-12-2019 08:14
04-12-2019 08:14
I just downloaded this app and it WORKS!! Fitbit and Samsung health are now communicating!
04-15-2019 13:34
04-15-2019 13:34
How did you make it work? I looked through various options on my phone (Samsung A5), on fitbit app, on Samsung health, and nothing... 😞
Best Answer04-25-2019 17:43
04-25-2019 17:43
What app did you download to get them to sync ?
Best Answer04-25-2019 17:59
04-25-2019 17:59
I ended up downloading fit and healthy by Jason lo on google play store. Works well cause it syncs itself so instead of going to both apps to update you can just use this one third party app and it will sync the other two.
06-13-2019 21:57
06-13-2019 21:57
What app?
Best Answer06-15-2019 19:22
06-15-2019 19:22
Fit and healthy by Jason lo is what worked for me
Best Answer07-20-2019 08:33
07-20-2019 08:33
The app is called "Health Sync"
07-21-2019 16:02
07-21-2019 16:02
I agree! I should've paid the extra and got the Samsung watch!
07-29-2019 18:49
07-29-2019 18:49
How did you get them to link?
Best Answer08-05-2019 23:55
08-05-2019 23:55
Download the app "Health Sync", it works.
10-07-2019 09:49
10-07-2019 09:49
Thank you for mentions the Health app. that sync all my apps to fitbit. I have Samsung S, Google fit and Fitbit and now they all talk.
10-11-2019 08:32
10-11-2019 08:32
How? can you please share the steps?
