11-30-2018
09:33
14:34
11-30-2018
09:33
14:34
I only get option on fitbit 3 to select running, walking and swimming. Is there a possibility to add different ones? Aqua aerobics, yoga, Pilates...
Help! I 😊
11-30-2018 10:05
11-30-2018 10:05
Welcome on board @Katatina, it's nice to see you here! Users can choose from over 15 exercise types—including run, interval workout, swim, and yoga, to customize the app with your favorite workouts. If a specific exercise isn’t available, choose workout as your exercise type.
Fitbit app:
Fitbit.com Dashboard:
Hope this helps, let me know if you need further assistance!
11-30-2018 10:05
11-30-2018 10:05
Fitbit app:
12-29-2018 06:09
12-29-2018 06:09
Is there anyway to add either "dance" or "zumba" to the exercises???
12-29-2018 06:15 - edited 12-29-2018 06:16
I would choose it as "workout" and then you can go into the dashboard and rename it when you're done with the exercise. It's going to calculate calories the same regardless of what it's named.
12-29-2018 07:44
12-29-2018 07:44
01-22-2019 12:00
01-22-2019 12:00
Responding to the recommended way to add to the exercise choice list.
there is no “gear” at the upper left in the dashboard mode. I have the tracker 3. I need to add stationary bike to my choices. when Exercising I have been putting the. Tracker on the pedal. Not wearing it on my arm. As it does not register as exercise. I have been adding it manually under bike but that’s not very accurate. Please help.
01-22-2019 12:02
01-22-2019 12:02
there is no “gear” at the upper left in the dashboard mode. I have the tracker 3. I need to add stationary bike to my choices. when Exercising I have been putting the. Tracker on the pedal. Not wearing it on my arm. As it does not register as exercise. I have been adding it manually under bike but that’s not very accurate. Please help. NanciB
02-08-2019 07:36
02-08-2019 07:36
Biking only registers through a GPS, so when you're on a stationary bike, you're not moving. Treadmill may be a better option.
02-11-2019 11:45
02-11-2019 11:45
I also do not have the settings gear anywhere. I need to add yoga to my exercises. Appreciate any help
02-13-2019 14:22
02-13-2019 14:22
What if you don't have "exercise shortcut" icon? Under goals It just says "exercise" and when I tap on it. It takes me to exercises that came with the Fitbit. I have no option to change and add. I'm looking to add my personalized HIIT workout.
02-13-2019 14:54
02-13-2019 14:54
It’s a little different than described. From
the app, you click on the Fitbit icon on the top left
02-13-2019 15:01
02-13-2019 15:01
02-27-2019 06:36
02-27-2019 06:36
There is no option to edit the workout selection or interval workout timings.pls help.Android OS with charge 3
02-27-2019 07:37
02-27-2019 07:37
Does the 15 include rowing? I currently use a charge 2 and keep getting offers to up grade, as I row a lot that would tip me over the edge I think
Thanks
Mike
03-02-2019 14:04
03-02-2019 14:04
No rowing... Available exercises:
Hike
Martial Arts
Tennis
Kickboxing
Golf
Bootcamp
Bike
Treadmill
Weights
Elliptical
Circuit Training
Workout
Stairclimber
Interval
Swim
Spinning
Run
Pilates
Yoga
Walk
03-02-2019 18:12
03-02-2019 18:12
03-18-2019 17:58
03-18-2019 17:58
why is this not available on my android app? I only have 6 exercises to choose from on my charge 3!
03-18-2019 18:00
03-18-2019 18:00
I have the same problem! I can't add an exercise on my android app!
03-18-2019 18:06
03-18-2019 18:06
03-18-2019 18:32
03-18-2019 18:32
Use a computer. You should have the options.
