10-08-2018 13:19 - last edited on 12-24-2020 15:13 by LiliyaFitbit
Just received my charge 3. The "workout" exercise shortcut is missing. This is the option I used EVERY DAY on my charge 2. Please help.
10-08-2018 15:09
10-08-2018 15:09
You'll have to edit the exercise shortcuts. This is how:
Hope that helps!
10-08-2018 15:57
10-08-2018 15:57
I also want the workout option, but I can't see the Edit selection to add more exercises like on Charge 2.
10-08-2018 16:27
10-08-2018 16:27
Looks like on Android, you have to "swipe left on any shortcut to remove".
10-08-2018 17:43
10-08-2018 17:43
Thanks! Got it 👍
Best Answer10-08-2018 18:00
10-08-2018 18:00
Glad to hear it!
If you want, you can accept my answer as the solution, so the moderators will know this question was answered.
01-08-2019 14:41
01-08-2019 14:41
I don't have an edit button in top right corner when I go to exersise shortcuts. It tells me select up to 6 activities on your fitbit 3.. non of them is workout or circuit 😞
Best Answer01-08-2019 14:49
01-08-2019 14:49
Edit option (plus sign) will appear when you remove at least 1 exercise (it's hidden when you already have 6 shortcuts in the app visible). It's kind of poor... would be nice if they had this plus sign greyed out or at least mentioned that you need to remove at least one exercise option to have edit functionality enabled.
08-07-2019 07:44
08-07-2019 07:44
Agreed, not too intuitive
@RiseAndShine wrote:Edit option (plus sign) will appear when you remove at least 1 exercise (it's hidden when you already have 6 shortcuts in the app visible). It's kind of poor... would be nice if they had this plus sign greyed out or at least mentioned that you need to remove at least one exercise option to have edit functionality enabled.
or user-friendly
Best Answer08-20-2019 09:15
08-20-2019 09:15
Brilliant thanks!!! I've had this watch for nearly a month and moaned about the lack of activities. I'm glad I finally searched for the solution
Best Answer08-20-2019 09:32
08-20-2019 09:32
Best Answer04-29-2020 21:10
04-29-2020 21:10
Does this also apply to the CHARGE 4.
I can't see the option.
I use this for strength training and HIIT
I wanna see the option on the watch
But it seems they removed the option for the supposedly "better, newer" Fitbit
I only have
"Run, bike, swim, treadmill, outdoor workout, and walk"
This makes me kinda want to return it. Cause all of them are a little redundant as they're too similar. They're all cardio and distance related with no interval per se. And I can't figure out how to use Spotify on it either.
And if I have to buy some "PREMIUM" THING for an ALREADY expensive watch that advertised features as automatically accessible without making it apparent that it has to be paired with an additional costly service, thatd be upsetting.
It's my first Fitbit... Someone please help me figure out how to use this to track my activities.
Best Answer04-29-2020 21:56
04-29-2020 21:56
I don't know how to add a picture. But MINE DOESNT EVEN SAY THAT ON THE BOTTOM
LIKE LITERALLY THE OPTIONS THEY GIVE ME ARE IT.
IM FRUSTRATED AND ABOUT TO JUST BUY AN EARLIER OPTION.
I CARRY MY PHONE EVERYWHERE..
AND IF I CANT USE SPOTIFY AND CHANGE THE MUSIC while also TRACKING THE EXCERCISE. then all these new features are useless and the ones I like have been taken away. Strength and interval
Best Answer04-30-2020 08:36
04-30-2020 08:36
Kelsey all I can find is Exercise Goals - Auto-Recognize - no way to add or remove Activities. For an unknown reason, BIKE disappeared from my Charge 3 and I got PILATES 4 tmes. Reset dosn't help.
02-26-2021 14:16
02-26-2021 14:16
Me too! I had BIKE option the other day (using it first time on my Versa 3)..the next time I want to bike, the BIKE option has gone..like you, Pilates is shown 4-5 times. What the hell is going on???
Best Answer03-01-2022 11:51
03-01-2022 11:51
I followed your helpful tips. Under settings I now have the 6 activities I want. But they do not show in under log previous. If I type them in the exercise is not recognized. Have not had a chance yet to see if they will be auto recognized.
