05-11-2023 13:37
05-11-2023 13:37
How do I change my charge 5 from one ipad to another ipad.
05-11-2023 17:51
05-11-2023 17:51
Thanks for getting back to us and for the clarification @tommac100.
Please follow the advised troubleshooting steps from my previos posts in order to switch the Charge 5 to the other iPad.
05-11-2023 13:40
05-11-2023 13:40
Hi @tommac100 as long as the iPad is compatible and the app is on it - just log in as usual.
05-11-2023 14:20
05-11-2023 14:20
Thanks for the reply, but I believe the on line account keeps track of the ipad you were using. Somehow I believe this needs to be changed so the new ipad is recognized.
05-11-2023
14:34
11:37
05-11-2023
14:34
11:37
Welcome to the Fitbit Community, @tommac100. Thank you for sharing your iPad set up inquiry.
If you're replacing the original iPad and no longer using it. You can set up up your Charge 5 as a replacement device on the new iPad and continue using it. Make sure to sync your device before the set up process.
Thank you for your advise @Odyssey13.
05-11-2023 17:16
05-11-2023 17:16
05-11-2023 17:51
05-11-2023 17:51
