The alarm on my Charge 5 regards working as optional. It seems to set, and sometimes does, but even set it frequently doesn’t go off. With the Charge 4 I thought it would be great to be able to set the alarm directly on the watch, but I’ve changed my mind completely. The Charge has been three step backwards to an audio alarm for me.
01-05-2022
09:04
11:14
01-05-2022
09:04
11:14
Hello, welcome to the Fitbit Community forums, @Liosag.
Thank you for sharing that you've been experiencing this inconvenience with your Charge 5.
Before considering other options, please try to remove and re-add the alarm, as described in this article. This has been helpful for other users experiencing something similar.
In addition, please try to complete a three pulse restart following the steps here below:
Hope this helps, I'll be around.
01-19-2022
07:27
10:50
01-25-2022
11:56
19:49
EstuardoFitbit
Ill try. Is this a restart?
Best AnswerBadlands, Surely you don't have a Charge 5 with infinite battery life. "Charger" refers to the cable with the charging device (which is a small rounded magnetic box-shaped affair with 2 connector pins) attached, one end of which cable is a USB plug. On that USB plug is a flush round button. THAT is the RESET BUTTON.
12:18
11:15
08-18-2022
12:18
11:15
@Badlands19 Thank you for your reply, let me know how it goes.
Yes, this would be to complete what is called a three pulse restart. You can find the button at the end of the USB plug of the charging cable.
I'll be around.
10-06-2022
07:44
06:45
10-06-2022
07:44
06:45
@Deekman4 There used to be an option to do this on the Fitbit, but it's no longer available with the most recent devices. If you haven't done so already, I recommend that you post this idea in the Feature Suggestion board of the Community, since this section is regularly monitored by the team of developers. Make sure to post your idea including as many details as possible.
Welcome to the Community forums, @stevyf. Thanks for sharing this update and for confirming that your alarms started working as expected after the restart procedure.
Have a good day.
Best AnswerCoincidentially happened again to me yesterday and I over slept. Restarting didn't work but in the app I noticed there was a watch update due and after doing that it worked again.
Still not great that it randomly doesn't work
09:26
11:15
01-18-2023
09:26
11:15
Hi everyone, and welcome to the new users in the Fitbit Community.
Thank you for confirming that you've been having the same problem with your Charge 5 and that you already tried a few troubleshooting steps.
In this case, if you already tried all the recommendations mentioned here earlier and you continue to experience the same problem, I do recommend that you get in touch with the Customer Support team for further assistance with this. They will let you know how to proceed.
The best way to get help for this problem is to chat with us online or give us a call. You can click here to get connected.
See you around in the forums.
Best AnswerMy charge 5 alarm failed to go off in December and I followed this advice and it worked. Three times this week my alarm hasn’t gone off again. I’ll follow these instructions again to hopefully solve it but can you explain why this is still happening? It’s an alarm…how can Fitbit mess up the function of the alarm and why hasn’t a fix been released to sort it? Will a bug fix be released? This is so deeply disappointing. It’s a good job that since the issue with my charge 5 alarm in December and my inability to trust it ever again, I set my iPhone alarm as a reliable backup every single time otherwise I’d have been late for work three times this week. It’s really poor.
