05-06-2022 05:34
05-06-2022 05:34
My IPhone 12 mini keeps asking me to turn on sync in background for my charge 5. I have this set up I believe!! Done everything that the instructions say.
keeps asking.
I have to manually update by pulling down the sync when I go into the app.
Best Answer05-13-2022 04:44
05-13-2022 04:44
Hello again @herbiesteve
Yes, pulling down on the screen to get the figures to update is normal for me as well. There used to be an “all day sync” feature but it was removed several updates ago on the Fitbit App. Here is the reason from Fitbit:
"To improve your experience with notifications, syncing, and firmware updates, we removed the option to turn off all-day sync from the Fitbit app. When your phone is near your Fitbit device with Bluetooth turned on, it periodically syncs with the Fitbit app to update your stats and download available firmware updates. More frequent syncing rarely, if ever, noticeably decreases your device’s battery life"
So, like you, I find myself swiping down immediately on my Fitbit App to sync my data because when I open my Fitbit app I want to see my recent data right away. It will indeed sync on its own if I don’t swipe down but it might be a a few short mins until it does so.
😃 I hope that answers your question. I’m happy to see the pop up messages you were receiving have stopped as well. Do you feel I have helped answer your question resolve the issue? Keep me posted
Best Answer05-06-2022 05:51 - edited 05-06-2022 05:52
Hello @herbiesteve
It sounds like your background app refresh is disabled. Let’s check… Tap on your iPhone Settings, then tap General then Background App Refresh. Look to ensure the Fitbit setting to On.
😃Let me know how it goes
05-06-2022 06:06
05-06-2022 06:06
Thanks. This is done. Here is the pop up I am getting is this
Best Answer05-06-2022 06:08
05-06-2022 06:08
Sorry. To be clear, what you suggested was already done. Thanks.
05-06-2022 06:19
05-06-2022 06:19
Try this to see if it helps: On your iPhone tap on settings. Scroll down and tap on Privacy. Tap on Location Services > Fitbit > Always.
05-06-2022 06:34 - edited 05-06-2022 06:37
I believe I finally figured it out…. Open your Fitbit App, tap profile picture then scroll all the way down an tap notifications. Make sure your Force Quit Reminders is disabled or enabled (whichever ever you choose). It reminds you to keep running Fitbit App in the background
05-06-2022 06:46
05-06-2022 06:46
Ok , this is enabled. What does that even mean?
if it’s on I get a reminder to let the Fitbit app remain open in the background? Not logical if what it really means is “open app and sync manually”?
Anyway, thanks, but I’m still not sure if my Fitbit is able to sync in the background? 🤣🤣
Best Answer05-06-2022 07:09
05-06-2022 07:09
😉 maybe his will add clarification: https://community.fitbit.com/t5/iOS-App/quot-Open-the-app-to-sync-your-stats-quot-notification-keeps...
05-06-2022 11:09
05-06-2022 11:09
@herbiesteve - I have one more thing to add. After you have followed @SunsetRunner‘s instructions, then do is this:
This should “set” all the changes you specified.
05-07-2022 00:18
05-07-2022 00:18
All the above was already in place. All I did was turn off the “force quit reminders” which we all agree is a weird thing anyway?
thanks for your interest and I have reset the Fitbit as instructions say. I’ll see what happens over today.
05-07-2022 07:03
05-07-2022 07:03
Keep me updated on how it goes @herbiesteve 😃 I’m hoping for success
Best Answer05-13-2022 00:08
05-13-2022 00:08
So, the messages have stopped. But I am still not sure if my Fitbit is remaining open in the background.
when I open the app, I have to pull down on the screen to get the figures to update. Is this normal??
05-13-2022 04:44
