Announcing the release of Fitbit Firmware Update 1.188.58.
This update should now be available to all customers! If you have any difficulty updating, make sure you are following the directions in How do I update my Fitbit device?. If you choose to post about your issue, provide as many specific details as possible in your post so that we can assist you.
*Firmware releases are not distributed based on region or location and can reach anyone no matter where you reside. We do not recommend performing a factory reset to force the update to your device as your data will be lost and you may not get the update. Please be patient and wait until you see the update banner inside of the Fitbit app to begin the firmware download.
WHAT’S NEW AND FIXED
Full release notes from previous updates can be found here.
HOW DO I UPDATE?
12-15-2022
00:19
09:44
DavideFitbit
12-15-2022
00:19
09:44
DavideFitbit
I see updates are generally messing things up, no stats this morning after update on IOS 15.6.1
After a few attempt I have got the stats / sync to work again. Reset C5 with button, turn bluetooth off on phone, restart phone. First time message that bluetooth was off when it was working - then it worked a bit slow but working.
Best AnswerManaged to restart and sync my device and it is back to where I want it! Not sure yet what changes there are with the firmware!
Best AnswerHi,
I've update to v.1.188.58 as I was expecting this to fix the battery drain issue that was caused y 1.171.50. It seems this didn't fix the battery drain problem, my Charge 5 still only lasts 6 to 7 hrs. Any news on the fix?
Just a guess: Fixing the issue not connecting to GPS once lost while in an activity. Will test today
Hi everyone, I've moved some of your posts to this thread so we can keep the forums more organized. Thanks for taking the time to share your feedback and comments.
As some of you have mentioned earlier, this update brings some bug fixes but there are no other visible changes on the device. Some firmware updates are exclusively released to address user-reported issues. You can find more details in this article on how to update your device successfully.
I'll mark this post as the Best Answer, not because a specific issue has been resolved, but so other members can know why this update was released and avoid any confusion.
I noticed some of you mentioned a few issues, let me know if you were already experiencing these problems or if you started having issues right after you updated the firmware.
@goarr @robinrunner66 @puj @Microqueen Please make sure that you've followed the steps provided in this article. to improve battery life in general and complete a three pulse restart using the charging cable by following the steps listed here. Keep in mind some of the features that make the battery drain faster than usual are:
@mchili If you're still having issues with the notifications, make sure to follow all the steps listed here, that you have the latest version of the Fitbit app installed and to check all the compatibility requirements here. Keep in mind that you won’t see notifications on your Fitbit device if you turned on the Do Not disturb Icon or Sleep Mode.
If the issue persists, try disabling the notifications completely on the Fitbit app and set them up again.
I'll be around.
And as of last night... don't "charge" at all lol
Charges upto 99%, but as soon as you remove cable.. it dies and on reconnecting its at 1%.
Thank goodness got a replacement on the way...
Has anyone who successfully updated to 171.50 tried version 188.58 and not experienced any battery issues? I was one of the lucky users who installed 171.50 and have been running it without any issues.
My warranty was up on 11/24/22, so if 188.58 causes problems, I'm out of luck getting a replacement.
Gary D.| Feeding Hills, MA MBG PE
Pixel Watch 3, Pixel Watch 4
Best Answer@DavideFitbit thanks for the advice (these are steps that I had already taken multiple times) and although the notifications began to work again AFTER I removed the charge 5 and re-added it, plus restarted it, etc, it only lasted for an hour, now back to none!! We should not have to constantly "tweek" a device every time there is some kind of update! I don't want to have to go back to my older trackers that have unreadable screens!
Best AnswerHi, I'm unable to find the SpO2 clock face, can advise which one of the 25 clock faces? Thank.
Best Answerin reply to
Tested yesterday evening and this morning. Not connecting to GPS once lost in an activity (firmware 1.717.50) bug is fixed.
Best AnswerI've had to restart my watch 5 times since the firmware update. Ive rarely restarted prior to thst. This morning I noticed that the watch stopped recording both my heart rate and steps, after 3 restarts in a 10 minute time frame it finally started recording both.
Also my GPS maps are way off compared to before the update, I'm certain that I don't walk in a zig zag pattern.
I’m constantly restarting it. Still not getting notifications. I don’t think a replacement would work any better. Back to wearing my old Apple Watch in the meantime which never fails me..
Performed the update yesterday. I lost my clock after it and i found no way to have a clock back on my device. When i double tap there is an error message saying try to install a new clock, but i tried with 5 different ones and cannot be installed due to error. ---now solved. I let the fitbit app open for 30minutes and let complete all the pending processes for synching and updating the Charge 5. At the end the clock was correctly installed.
Best Answerwould suggest you try reset the device using the button on the usb part of the charging cable, you should press the button 3 times one second each. Good luck.
