02-17-2022
13:25
13:02
DavideFitbit
02-17-2022
13:25
13:02
DavideFitbit
This Charge 5 is a disappointment. Doesn’t record heartbeat right at all. My last try before changing products. My original Fitbit years ago was really reliable.
charge doesn’t record bike heartbeat, spin at HOTWORX, etc. readiness score a mystery. Stops tracking if I charge the Fitbit.
overall very erratic.
02-19-2022
13:01
11:43
02-19-2022
13:01
11:43
Hello, welcome to the Fitbit Community forums, @Roy1522.
Thank you for sharing this information about the inconvenience you've been experiencing with your Charge 5.
Before considering other options, I recommend that you try restarting the device using the three pulse restart method mentioned here below, instead of the restart option found on the Charge 5 itself:
In addition, please follow the instructions in this article to improve the accuracy of heart rate information and check the information mentioned here about other factors that could affect your heart rate reading, this has been useful to other users who have experienced something similar.
Regarding the problem with the readiness score, if you're not getting heart rate information, you won't receive readiness score information. In the meantime, please make sure of the following:
Thank you for sharing all your feedback and comments about this.
02-19-2022 13:10
02-19-2022 13:10
I’ve returned it. I’ve had three prior fitbits. None have perfect heart rate measurements. I’ve done all the tricks. None worked. Also, time to improve it shouldn’t be this hard.
I’m using my aria. Until I leave fitbit for something else. I loved my first one 5-6 years ago. Since it died I’ve struggled to find a good one.
Also, the bands aren’t great.
Best Answer02-24-2022 09:38
02-24-2022 09:38
@Roy1522 Thank you for sharing this update. I'm sorry to see that it wasn't possible to resolve the problem with the heart rate and that you had to return your device due to this inconvenience.
I appreciate all the information that you've shared about the product and the team continues to work to improve the Fitbit experience.
See you around.
05-06-2023 09:11
05-06-2023 09:11
Is the readiness score a premium feature?
(I thought it was equivalent to my garmins "body battery.")
09:36
09:31
05-14-2023
09:36
09:31
@vbenar Thanks for your inquiry about the Readiness Score.
As you mentioned earlier, the Readiness Score is indeed a Premium feature. You can find all the details about this feature and how to use it in this article.
