01-18-2022
17:06
06:06
DavideFitbit
01-18-2022
17:06
06:06
DavideFitbit
Hi. My Charge 5 is frozen on the timer display. do I need to reset watch/ how?
cheers.
06:06
10:50
01-19-2022
06:06
10:50
Hi, it's good to see you around the Community forums for the first time, @ihatepasswords.
I appreciate the information that you've shared about the problem you're experiencing with your Charge 5.
Before considering other options, please try to complete a three pulse restart procedure following the steps listed here below:
Let me know if your device continues to be stuck on the timer after this procedure.
I'll be around.
Best Answer01-19-2022 07:42
01-19-2022 07:42
Mine is also getting stuck and the stopwatch app is gone. Have rest it multiple times and now it gets stuck on various apps.
11:17
19:49
EstuardoFitbit
01-25-2022
11:17
19:49
EstuardoFitbit
@Lburdick162 Thank you for sharing that you've been experiencing the same inconvenience with your Charge 5 and that you already tried the restart procedure suggested earlier.
I've been informed that you already contacted the Customer Support team for further assistance with this. In this case, they will let you know how to proceed.
Have a good day.
07-13-2022 04:47
07-13-2022 04:47
Hello, it would be great if you told us how support was going to help @Lburdick162 resolve the problem.
I let my stop watch run past 24 hours and now only have the countdown timer to select on that screen. no more stopwatch.
how does one fix this issue.
I was mostly enjoying this Fitbit until this happened.
cheers
09:16
19:50
EstuardoFitbit
07-23-2022
09:16
19:50
EstuardoFitbit
Welcome to the Community forums, @AndrewOZ2.
Thank you for sharing all this information and for confirming that you're having the same inconvenience with your Charge 5.
There are some general recommendations that are usually helpful with any type of issues. If you haven't done so already, please try these additional steps that have been useful for other users:
In addition, please keep in mind that a new firmware version has bene released to address this problem, you should receive it soon as well. You can find more information here on how to update your device.
