07-04-2024
		08:56
		11:55
			EstuardoFitbit
		07-04-2024
		08:56
		11:55
			EstuardoFitbit
Hi, my charge5 was working earlier today but went blank. Then it showed cross and red circle. I have tried everything that has been suggested on different forums. Pulse restarted, cleared cached, uninstalled and installed app, unpaired and now i can't even pair it as it won't start. Any other solution?
 Best Answer07-04-2024 11:13
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              07-04-2024 11:13
Hello there @HumaWaqar, and welcome back to the community.
Although I really appreciate all the effort you invest in fixing these inconveniences, there are some things that could have been done differently. Actually, we do not recommend unpairing the device while experiencing screen issues since that makes the device unable to set it up again.
Since you tried the steps and they didn't work, I need additional information from you that would best be shared privately. I’m sharing a link to a form for you to fill out so we can look into this further. Please go to the following link: https://support.google.com/fitbit/contact/fitbit_community.
I’ll keep an eye out for your response specifically, so please let me know once you’ve filled it out.
07-04-2024 11:13
                              07-04-2024 11:13
		07-04-2024
		17:51
		11:22
			RodrigoMFitbit
		07-04-2024
		17:51
		11:22
			RodrigoMFitbit
Hi, I have filled out that form given on link. Thanks
Hi, any leads on way forward?
any update? what can be done?
 Best Answer07-10-2024 12:22
                              07-10-2024 12:22
Hi there @HumaWaqar, and thanks a lot for your effort.
Please note that our dedicated team is currently reviewing your case and you should receive a response to your email shortly.
