09-12-2024
05:06
08:15
AndreaFitbit
09-12-2024
05:06
08:15
AndreaFitbit
My Charge 5 stopped working yesterday 11/09/24...around 10am Brisbane time....wouldn't sync....steps weren't increasing....wouldn't charge. Tonight it has just swtiched off completely 12/09/24 approx 10pm (no lights on the back...nothing on the screen. Any idea
Moderator Edit: Formatting.
Best Answer09-12-2024 05:48
09-12-2024 05:48
Hi, @PattySue63 welcome to the community, you may like to review this article Why isn't my Fitbit device's battery charging? - Fitbit Help Center. Test your USB socket to confirm it's "Live" and follow the other advice. If you are still stuck please post here again, how long have you had your Charge 5?
Cheers
Gr4ndp4 | UK
09-12-2024 06:46
09-12-2024 06:46
My Charge 5 also stopped working at the around the same time. I have checked the charge. When on charge I see the Fitbit logo on the screen, but it does not sync with the mobile device or display the date and time.
09-13-2024 08:02
09-13-2024 08:02
Hi, @Brian_McC , welcome to the community, have you tried restarting your Charge 5? This video demonstrates the process at 1:30. Let us know how you get on by posting here again.
Cheers
Gr4ndp4 | UK
09-13-2024 08:17
09-13-2024 08:17
Same here. In fact, every fitbit I've owned has done this. I'm about done.
09-13-2024 09:40
09-13-2024 09:40
Welcome to the Fitbit Community, @PattySue63, @Brian_McC, @Nerdyt. I'm sorry to hear that your Charge 5 stopped working and I'll be happy to assist.
@PattySue63, thank you for trying to charge your tracker and have you already checked @Gr4ndp4's advised troubleshooting steps.
@Brian_McC, I would advise to set up your Charge 5 again with these steps:
@Nerdyt, I understand how frustrating this could be and could you mention which steps have you tried?
Best Answer09-13-2024 09:45
09-13-2024 09:45
09-13-2024 15:37
09-13-2024 15:37
Best Answer09-16-2024 01:34
09-16-2024 01:34
I finally got it to work...had to do the 'restart' 3 push option a few times which seemed to drain the battery completely (I recharge every morning while I shower, so there is no way it would have been at 4% after 1 day of not working at all). I then left in on the charger overnight and it was fully charged when I checked it the next morning. I could then manually add in my missed steps/sleep (although the data isn't accurate of course).
09-16-2024 07:04
09-16-2024 07:04
Black screen of Charge 5,; I've tried the recommended steps of clicking the button on the USB and unplugging. Neither appears to have resolved the issue. VERY frustrating. Did Fitbit do an update?
09-16-2024 07:06
09-16-2024 07:06
I started having this issue last night as well.
09-17-2024 18:11
09-17-2024 18:11
Hi AndreaFitbit, do you have any recommendations to fix the Black screen on my Charge 5? I've tried the reset steps (reset button on charging cord) numerous times to no avail. It still records steps that I can view on the app. Thanks for any assistance.
09-17-2024
22:13
11:38
AndreaFitbit
09-17-2024
22:13
11:38
AndreaFitbit
Yep, same hear in SA. after updating the app last week. This is my third I think that has done it. I'm convinced this is an engineered software failure.
Yep, has happened to me on three different Fitbits.
09-18-2024 17:15
09-18-2024 17:15
This is my 4th fit bit. Why won't they last more than 12 - 18 months? Has anyone been able to get theirs to last longer? I am on a fitbit charge 5 and would consider the 6 but at about $160 a pop it's a yearly expense of $80 when they die so soon.
09-18-2024 18:47
09-18-2024 18:47
09-22-2024 02:58
09-22-2024 02:58
A reboot when the Fitbit charge displayed the time again, allowed it to function for a week. However, now it has reverted to just showing the Fitbit logo on the device screen and disconnected in the app ( looking for device at 70% charge).
Best Answer09-22-2024 03:04
09-22-2024 03:04
I had to wait for the device to drain of battery, it was stuck showing the Fitbit logo on the device and looking for device in the app. The button on the charger lead had no effect, when the reboot process was attempted many time.
once I was able to see the time again, after a recharge, I followed the device reboot process. I was then able to use the device for three days. Yesterday it again reverted to the Fitbit logo on screen and “Looking..” on the app connection screen. Battery was 69% charged. 24 hours later, still the same state.
Best Answer09-22-2024 03:59
09-22-2024 03:59
I was able to drain the battery several times and get it running again for about a day each time after reconnecting it to the charger before the Fitibit logo would just flash over and over, then the 3rd time it just went black and doesn't even "buzz" when I connect power to it any more.
Best Answer09-22-2024 13:26
09-22-2024 13:26
Hello @Scet , @Brian_McC , @ED_G
One of our users discovered that they were able to get their Charge 5 working again after exposing it to freezer temps, then allowing it to come up to room temp before putting it on the charging cable and doing a restart. This thread (<-- click link) describes what they did.
This worked for some users, but not all. Although there's no guarantee that this method will work in your case, it might be worth a try.
Best Answer09-22-2024 18:58
09-22-2024 18:58
