03-22-2024
08:20
14:16
03-22-2024
08:20
14:16
This charge 5 goes into reset randomly, daily , and needs to be put on charger to get back. Always shows over 50% battery when this happens.
03-22-2024 14:19
03-22-2024 14:19
Hi there, @BDANIEL230. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention, we're here to help you!
There are some general recommendations that are usually helpful with any type of display issues. If you haven't done so already, please try the steps listed here below that have been useful for other users:
03-22-2024 12:10
03-22-2024 12:10
Hi, @BDANIEL230, may I suggest you reset your charge 5? This video demonstrates the two options open to you. Let us know how you get on by posting here again.
Cheers
Gr4ndp4 | UK
03-22-2024 14:19
03-22-2024 14:19
04-05-2024 11:34
04-05-2024 11:34
Again, as soon as I connect the charger the watch comes back to life but shows the time when it stopped, usually around 4 or 5 hours after I put it on. I have changed back to the default clock face and reset to factory but it continues to do this. I have done the 3 pulse restart a few times but the behavior exists.
04-09-2024 12:56
04-09-2024 12:56
Same thing is happening to me. Spent way too long trying to fix this.
Since I've had the device since 2022 (outside the warranty period), I'm guessing there is no reason to contact customer support.
04-09-2024 13:21
04-09-2024 13:21
My charge 5 also restarts, but it is a constant loop. It shows the clock face, goes black, then shows the fitbit logo, then black again, then the clock face (and repeat). The whole cycle takes about 20 seconds.
