07-03-2022
13:28
04:53
07-03-2022
13:28
04:53
hi everybody, i bought the new charge 5 back in november. now the screen is not working, it is only displaying 'static'. see pic attached
inside the app, the fitbit still seems to be working, steps are being counted etc. it's just the screen that's messed up
has anyone else had this problem, and is it possible to get it to reset it or something? or should i seek a replacement altogether?
thanks in advance
Best Answer07-03-2022 16:47
07-06-2022 07:27
07-06-2022 07:27
hi @Julia_G , thanks for replying.
no, restarting didn't fix it. i think the screen is wrecked and i need to seek a replacement
best regards, linda
Best Answer07-06-2022 18:36
07-06-2022 18:36
I’m having same problem, let me know if you get it figured out.
07-06-2022 21:32
07-06-2022 21:32
I contacted support and went through there tech support. They are sending me a new one. Did it through chat. They were very helpful
