03-08-2022 05:14
03-08-2022 05:14
Since midday yesterday my Charge 5 Screen Wake quit working. Settings shows the option set to manual and grayed out. It was not on manual and was working fine yesterday morning. Can I fix this? Thanks!
Best Answer03-08-2022 05:34
03-08-2022 05:34
Hello @bepfarr
If you scroll down from the Clock Face screen and check to see if DND mode or Sleep Mode are set to On, that could be the reason why. Make sure they’re switched to off and you should be able to set your Screen Wake to Auto again.
I hope that helps.
03-17-2022 16:59
03-17-2022 16:59
Thank you! Yes Sleep Mode was on. Don’t know how it got turned on but your suggestion worked. Thanks very much!
03-17-2022 17:11
03-17-2022 17:11
I'm so glad it's fixed for you @bepfarr ! If it ever happens again, you'll know what to check first.
