Charge 5 stopped working properly
Charge 5 has stopped tracking.  Only 6mths old.  Also noticing battery is discharging rapidly.
1 REPLY 1
@mdwill Welcome to the Fitbit community!
Sad to hear that your Charge 5 isn't working as expected. I'd suggest trying to solve this issue by restarting your device following these steps:
1.) Connect your device to the charging cable which has to be connected to a power source.
2.) Press the button located on the USB Plug of the charger 3 times within 8 seconds, holding each press for about 1 second.
3.) Wait 10 seconds or until the Fitbit logo appears.
4.) Let your Charge 5 charge for an hour.
5.) Check the battery status of your device.
If this doesn't work for you, I'd contact Fitbit support to get further assistance:
Fitbit Support Contact
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2
