10-31-2025
02:32
07:15
10-31-2025
02:32
07:15
Is anyone else experiencing difficulty with their Charge 5? It just doesn't retain its charge and despite an overnight charge the display will go black within a couple of hours of charging. I have to keep my phone with me all the time to see what the time is.
Anyone able to recommend a better product to Fitbit please?
Welcome to the community forums @BerryMoyle.
Thank you for taking the time to share the information regarding the issue that you are experiencing with your Charge 5.
Sorry to know the situation with it. Thank you for trying to fix it on your own.
I'd ask you before considering other options to follow the steps listed in this help article in order to enhance the battery life of your device.
It's good to see you participating in the community @CB_Magdalen.
Thank you for this information about your Charge 5.
Can you see green lights back of the device or do you feel some vibration on it?
Have you followed the steps outlined here to confirm that the battery is charging correctly?
Best AnswerI also can't get mine to charge. Charge 5 model.
It went flat really suddenly during the night when usually it would last at least a few more days. Then I woke up and it was dead. Plugged it in and it knows the charger is plugged in - the fitbit logo comes up, it vibrates, then up the charging screen appears. It says it's charging but goes from 1% to 0% each time I try, then screen blacks out and it acts like it isn't plugged in anymore. Help!
I bought it second hand but have only had it for a few months so I'm really disappointed this is happening. I've tried the reset but that didn't change anything
