05-25-2024 16:44
05-25-2024 16:44
Charge 5 charge vibrating for hours non stop.
tired of this, it also hangs even when I sweat, with that logo, charge 5 suck I’m looking for Android Samsung watch.
Best Answer05-25-2024 19:31
05-25-2024 19:31
@Edm365f31 have you trying restarting your device? That is usually the first thing I do when I encounter unexpected behavior.
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
05-26-2024 03:52
05-26-2024 03:52
Hi there, @Edm365f31. Welcome to the Fitbit Community Forums. I'm sorry to hear about the issues with your Charge 5. I understand how you must be feeling. We're here to help!
If the restart recommended by @alexthecat doesn't help, as our last resort, I'd recommend performing a factory reset on your Charge 5. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
With the above being said, please sync your Charge 5 and then, proceed with the steps below in the order listed:
You can follow the steps to set up the device after that How do I set up my Fit-bit device?
Best Answer05-27-2024 09:05
05-27-2024 09:05
Done that no difference, problem is, charge 5 is hung just vibrating not able to connect back.
can this still be replaced, under warranty.
had issues with this right after I bought it, it gets moisture not really wet, and the logo comes up and I need to restart, and recharge.
Best Answer05-27-2024 09:07
05-27-2024 09:07
Done that, momentarily, vibration would stop then come back. Every time I charge just vibrate, initially just black screen, now with logo still vibrating.
