09-27-2024 09:39
09-27-2024 09:39
Never used readiness score, didn’t even know it existed before the latest update. I thought it was new? Anyway, the app keeps saying to wear my device for seven more days. It’s definitely been more than seven days. I look at the data and I have no scores whatsoever. Do I need to turn something on somewhere? Or is this just not functional?
02-18-2025
07:26
07:48
MarioSFitbit
02-18-2025
07:26
07:48
MarioSFitbit
Sleep and Readiness has been working just fine for passed month an a half.
Rich
Sent from my iPhone
RiekoC, I know I’m late in responding but after following your instructions and clearing other data and waiting several days to accumulate data both sleep but more importantly daily readiness started working and has continued working just fine since early January. Thanks much.
Moderator edit - Merged messages
02-19-2025 11:34
02-19-2025 11:34
Hi @Rvested
Thanks for your update. I'm glad to see that you're getting your Daily Readiness score. 👍
Best Answer02-26-2025 00:54
02-26-2025 00:54
Hi I’m still trying to get readiness working for my charge 5. I was a premium member on an older android phone but it ended mid Feb. I couldn’t update my Fitbit App on my Android so I have now switched the app to my work phone an iPhone SE and I have reinstalled the app and updated it to version 4.37. Readiness still does show and instead my Fitbit prompts me to go back to premium membership. But my understanding is the readiness is free to uk Fitbit members without having to take premium. Can you help at all? Thank you for reading.
Best Answer03-09-2025 07:41
03-09-2025 07:41
My daily readiness score stopped working March 4. I have a Pixel Watch 3 and Pixel 7 phone. The Fitbit app is on version 4.38. I've tried all solutions mentioned on this board, but still not working.
Best Answer03-09-2025 12:05
03-09-2025 12:05
Hello @ImagineXLS
Are you also having issues with sleep or heart rate tracking? The Daily Readiness algorithm uses data from your sleep tracking. If you're having problems with sleep tracking, you won't get a Daily Readiness score.
Best Answer03-09-2025 12:14
03-09-2025 12:14
No, sleep tracking is working fine.
Best Answer03-09-2025 15:15
03-09-2025 15:15
03-10-2025
04:16
12:33
ManuFitbit
03-10-2025
04:16
12:33
ManuFitbit
03-17-2025 16:35
03-17-2025 16:35
FYI - it's been showing up now. 2 days in a row. Hope it keeps up.
03-18-2025 03:55
03-18-2025 03:55
Same for me, 2 days in a row. I'm not getting my hopes up high that it'll last, though...
04-01-2025 08:51
04-01-2025 08:51
My daily ready to score on my Versa 3 was 15 for several months.So I recently purchased a new Sense, figuring I'd give that a try. So Far, my score remains at 15 - HELP!!!
Best Answer04-02-2025 11:52
04-02-2025 11:52
Hello @Ragu88
This help page explains how the updated Daily Readiness score is calculated (<-- click link).
If you are consistently getting a low Daily Readiness score, that indicates to me that some of your metrics are exceeding your personal limits. What do you see when you tap on the Daily Readiness tile? You should see the breakdown & what is causing the low Readiness score.
Best Answer04-02-2025 13:25
04-02-2025 13:25
04-04-2025 12:49
04-04-2025 12:49
Hello @Ragu88
That's definitely not the expected behavior.
When you open the page to look at your Daily Readiness score, what does it say for each of the metrics?
Are you an iOS or Android user? Which version of the Fitbit app do you have?
Best Answer04-04-2025 19:18
04-04-2025 19:18
Best Answer04-06-2025 11:40
04-06-2025 11:40
Hello @Ragu88
Thank you for your response & info. Unfortunately, your screenshots didn't upload to your post.
When you open the Daily Readiness page from the Today page, what do you see in the What impacted your readiness section? What do you see for each of these metrics?
Best Answer04-07-2025 06:49
04-07-2025 06:49
Best Answer04-07-2025 11:27
04-07-2025 11:27
Hello @Ragu88
Thank you for your response and confirming that you're not seeing anything on the Daily Readiness page that would result in a low score.
Although I'm not sure that this will work, you could try clearing the storage/data for the Fitbit app on your phone. Do a manual sync first. After you clear the storage/data for the Fitbit app, you will need to log back in. However, you shouldn't have any loss of data, especially if you do a manual sync first. Most likely, you won't see a change in the Readiness score until tomorrow.
I also suggest submitting this issue using the Feedback option in the Fitbit app
Although it's likely that you won't receive a response, the team receives & reviews the feedback reports.
Best Answer04-22-2025 04:12
04-22-2025 04:12
Ive been wearing my Fitbit Versa religiously since last year except for a couple of nights when the battery died. I have had NO readiness scores in the last year even though there is data for each of the factors and I'm a premium member. This feature stinks, and so does customer service. How do I personally get in touch with tech support? This forum and your articles are NOT resolving my problem.
This will be copy pasted as an app review with one star if it isn't resolved.
Best Answer04-22-2025 09:24
04-22-2025 09:24
I'm using a Fitbit Sense and while I do receive a Readiness score, it's been the same readiness score now for a couple of months -15. So far I've received no helpful response to resolve the issue
