06-28-2023
17:44
12:27
LizzyFitbit
06-28-2023
17:44
12:27
LizzyFitbit
Suddenly many people are dealing with sudden loss of battery and black screen with no possible way to fix it. Could this have anything to do with the update? It seems not so coincidental it's all happening at the same time.
11-01-2023 11:03
11-01-2023 11:03
11-01-2023 19:15
11-01-2023 19:15
11-01-2023 19:52
11-01-2023 19:52
Thanks, did not work. Any other steps/suggestions that may work ??
11-05-2023 19:24
11-05-2023 19:24
@SunsetRunner - Move on to another company. I chose Amazfit and have been using it for a little over a month now. Fitbit/Google is not interested in correcting their mistake that bricked so many Charge 5s.
11-29-2023 21:42
11-29-2023 21:42
It's Nov and I still have 188.58 on my charge 5. How can I update the firmware? all of a sudden my watch randomly shuts off. I've tried to reset it with the charging cable several times but same out come...randomly.
Best Answer11-30-2023 13:09
11-30-2023 13:09
You are probably going to have to upgrade to the Fitbit Charge 6 or switch devices altogether. There aren't many of us who've had luck getting our Charge 5's to work since the last update.
Best Answer11-30-2023 14:14
11-30-2023 14:14
I agree with you about software and infection. I've contacted customer service twice already and both times they had me change the clock-face because they believe that may be causing the watch to shut off. If this is the case WHY put third party software on your product. I can't update the firmware because it's not available so it's either I buy the new one or go elsewhere. I could be reaching far on this but maybe they're doing this so that the devoted Fitbit consumer will buy the newest watch...That's a risk they'll have to take. I have had the charge since day one but now thinking of going elsewhere if this isn't fixed. You would figure by looking at this community page that a lot of people are having the same problem and would Fitbit offer a solution, but haven't. Btw, they offered me 50% and not 30% but I can't use it for the charge 6.
Best Answer11-30-2023 14:19
11-30-2023 14:19
I'm using a replacement Charge 5, activated 8 Oct, with FW 188.58. It's been rock solid. I have zero desire to get newer firmware.
My one tidbit learned recently is that I was seeing some issues with the C5 properly registering heart rate during exercise, The answer for me is that I have dry skin, especially as humidity decreases heading into winter. I put just a tiny dab of common vegetable glycerin on my wrist before a workout and it's working perfectly.
Best Answer11-30-2023 14:21
11-30-2023 14:21
HI. yes I am one of those and never had this problem with other charge watches. I may be reaching on this but could it be that like many companies losing revenue after the pandemic. This is an attempt to try and get the devoted Fitbit consumer to buy the newest watch...If so many are experiencing this, why not issue a software update to fix the problem. The only fix that they offered me was a 50% which I can't use toward a charge 6. I'm rethinking my options like so many others.
Best Answer11-30-2023 14:31
11-30-2023 14:31
