01-11-2022 02:20
01-11-2022 02:20
Has anyone had their Fitbit charge 5 stop working and only showing the dots at the top of the screen? If so do I need to get a new one? Or is there a way to fix it?
Best Answer01-11-2022 02:49
01-11-2022 02:49
Hello @Kyrass
Yes, a few people have had the same problem unfortunately.
One thing that might help is rebooting from the charger. Put it on to charge then press the button at the USB end of the charger 3 times. Some people say to leave a couple of seconds between each press and others say to do it quickly.
Try both ways and see which works for you
I really, really hope that works for you!
If you changed your clock face just before this happened, there may be a connection and it may be worth changing it again.
Here’s a link to a thread where people talk about the same issue.
Good luck!
Best Answer01-14-2022 11:22
01-14-2022 11:22
01-14-2022 11:47
01-14-2022 17:28
01-14-2022 17:28
That worked for me also
01-14-2022 17:30
