04-24-2025 10:56
04-24-2025 10:56
A few days ago my Charge 5 stopped showing historical step count data. It shows current but when you click today’s steps to go to daily/weekly/yearly steps, the section that typically shows the data is just grey blocks. I’ve logged out of Fitbit and force stopped. No change
04-24-2025 12:41
04-24-2025 12:41
Same issue. As usual Fitbit app has problems and take ages to be fixed.
04-25-2025 08:51
04-25-2025 08:51
Same issue. Saw similar issue reported for Charge 6.
04-25-2025 10:59
04-25-2025 10:59
Hello @Rcnelson56 , @thesmallerhalf , @SpringMesa
Are you not seeing historical data for any other metric, other than steps? If so, please let us know which ones.
Please submit this issue using the Feedback option in the Fitbit app:
The feedback reports go to the team for review.
04-25-2025 13:54
04-25-2025 13:54
Will submit.
Historical data not showing up for Steps, Distance, and Energy Burned (calories). Other metrics are working.
04-26-2025 08:46
04-26-2025 08:46
Fixed problem: On iPhone.
Delete App (no data is lost)
Turn off phone & turn back on
Reinstall App
04-26-2025 09:14
04-26-2025 09:14
Hi everybody! Thanks for stopping by, I hope you're doing well.
Thank you for reporting this issue. @SpringMesa this is an issue more related to the Fitbit app. As @RiekoC has suggested, it a great idea to report this issue via the app itself.
In addition, i'm glad to inform that this issue has already been reported, escalated and currently being investigated. Some users have been able to resolve the issue by uninstalling/reinstalling the app as you @SpringMesa may have already noticed.
Any fix for this, well be releasing it as soon as it's available. I appreciate your patience.
04-29-2025 12:00
04-29-2025 12:00
Hi, is there an update on when the historical step data will be fixed within the app? Keith
Best Answer04-30-2025 11:47
04-30-2025 11:47
Hello @KEM1
The Moderator who posted in this thread will provide updates and let us know when the fix is rolling out.
04-30-2025 13:55
04-30-2025 13:55
I am having the same problem! When I log into fitbit.com, it reports an "internal server problem" and no data is displayed.
Best Answer04-30-2025 14:02
04-30-2025 14:02
This is fixed for me now! Deleting the app and reinstalling it works.
04-30-2025 17:25
04-30-2025 17:25
Gogr, Did you completely delete the app then go to the App Store and reinstall? Thanks in advance.
05-01-2025 05:17
05-01-2025 05:17
05-01-2025 06:34
05-01-2025 06:34
Hi everyone and warm welcome to the new members.
I appreciate your messages and your time in this process. I'm sorry to hear that you are experiencing this issue.
As previously said, our team is aware of this and still working on a fix. As Community Moderators, we will post any updates about this situation.
Could you please confirm if you tried to uninstall / reinstall the app ? This one time exception workaround worked for some users.
To do so, please try to:
1. Logout.
2. Uninstall the Fitbit App.
3. Reinstall the Fitbit App.
4. Login.
@gogr Thank you for your confirmation and @RiekoC I appreciate the support always given.
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
05-01-2025 09:34
05-01-2025 09:34
Me too. I can’t look at weekly which I tend to fixate on every night after my workout. It’s driving me bananas
Best Answer05-02-2025 09:52
05-02-2025 09:52
Same issue here. And even though there has been an update “to fix bugs” in the meantime the problem remains 😕
Best Answer05-02-2025 16:57
05-02-2025 16:57
While deleting and reinstalling App has solved historical data issue. I still have related problem:
Charge 5 screen will not turn on when battery level is still ~85% full. It seems to still track data. It also happens when I open App and swipe down to sync data. By connecting/disconnecting to charger several times, the screen will then work for a while. And data will be updated in App.
So everyday I need to connect/disconnect to charger several times to fix issue.
Best Answer05-23-2025 01:13
05-23-2025 01:13
Does this not delete data (as Apple warns it will)??
Best Answer05-23-2025 11:35
05-23-2025 11:35
No data is lost. See other replies that confirm this.
