08-09-2022
15:47
08:48
DavideFitbit
08-09-2022
15:47
08:48
DavideFitbit
Initially I could not sync my Charger 5 to phone. Now the only thing I have on the watch is a very dim clock face. Tried reset using charger cord reset button it did nothing. Can’t get to settings to try that reset.
08:47
06:59
08-10-2022
08:47
06:59
Hi, welcome to the Community forums, @Raplh480.
I appreciate all the information that you've provided about this inconvenience with your Charge 5 device.
In case you're able to see the display but it's a bit dim, please make sure you've disabled the Sleep Mode and the Do Not Disturb Mode on the device's settings, as these feature automatically make the screen darker.
In addition and if you continue to see the display is too dim, there are some general recommendations that are usually helpful with any type of display issues. Please try these additional steps that have been useful for other users:
Hope this helps, I'll be around.
Best Answer08-11-2022 15:22
08-11-2022 15:22
Thanks for reply. I cannot change any functions or pages on my charger. The home clock face comes on and it’s dim. I have tried the charger cord button reset with no avail. Being I cannot change any functions I am unable to try the reset on the watch in settings. Thanks
07:51
06:58
09-02-2022
07:51
06:58
@Raplh480 Thank you for your reply and for confirming that you already tried all the steps suggested.
In this case, since you already tried the restart procedure with the charging cable or if you're not able to see anything on the display to be able to change the brightness settings and you continue to experience the same problem, I recommend that you get in touch with the Customer Support team for further assistance with this. They will let you know how to proceed.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
See you around.
