12-15-2021 15:04
12-15-2021 15:04
My Charge 5 adds 12,000 to 15,000 steps when I first get out of bed. Either fix the software or make it manually adjustable so we can have a more accurate count. My Charge 4 never had this problem. Tell your progrmmers to fix the problem.
Best Answer12-16-2021 07:23 - edited 12-16-2021 07:23
Hi, thank you for sharing that you've been having this inconvenience with the Charge 5, @SweetJanOK.
Before considering other options, could you please provide a few extra details? Let me know if you're experiencing this problem constantly or if it happened only once (many steps being counted while you sleep). In the meantime, make sure to complete the restart using this method below:
I'll be around.
12-16-2021 08:21
12-16-2021 08:21
Best Answer12-16-2021 10:20 - edited 12-16-2021 10:54
Hello @SweetJanOK
The button is a bit hard to spot but is at the USB end of the cable.
Here’s a picture for you. Hopefully you can spot it.
On mine, the way it plugged in means it’s facing down so you can’t spot it easily.
Good luck with everything!
PS I recently saw someone (I forget who, sorry) suggest choosing that ‘Exercise’ period in your app and changing it to Driving or some other non-step based activity. I think that also allows you to edit or erase it too.
If I can find that post later, I’ll come back and add a link to it.
Found it! @EdsonFitbit posted an extremely helpful link in their post that I followed to get the information!
After all that, I forgot to post the link!
12-16-2021 10:47
12-16-2021 10:47
12-17-2021 05:57
12-17-2021 05:57
@SweetJanOK Thank you for sharing that you were able to complete the restart and that you already got in touch with the Customer Support team for further assistance. In this case, they will let you know how to proceed.
Have a great day.
