01-29-2022 18:09
01-29-2022 18:09
I’ve worn my Charge 5 for 3 weeks consistently, have the free 6 mos of Premium and still don’t have a readiness score. Is it bc I’m in the free trial?
It’s in contact with my skin, clean and I wear it 24/7.
Best Answer01-30-2022 00:25
01-30-2022 00:25
Hi @SunsetRunner.
I would recommend logging out and back into the Fitbit app (if on iOS 12 or lower) or uninstalling and re-installing it (on iOS 13+). If you are using Android it's worth clearing the apps cache to see if that helps. You could also try uninstalling and re-installing the app, but only if you are on Android 8.0 or higher (anything lower and you may not be able to re-install the app). It could just be a case of the app not pulling in the correct data.
The following Fitbit help article (here) says the following about not receiving a score. Although I'm not sure it's particularly helpful in your case.
Why don’t I see a daily readiness score in the Fitbit app?
