09-25-2024 18:37
09-25-2024 18:37
After recently receiving a replacement Charge 5, I no longer have access to all the watch faces (juxtaposed, bifrost, brisk and glimpse). I had access to these on my previous Charge 5 which was in use until about 10 days ago. The replacement Charge 5 is 3 days old. I tried everything mentioned in other posts to no avail. Any suggestions or was the access to these faces rescinded? Thanks
09-26-2024 04:21
09-26-2024 04:21
Hello @DocFaro and welcome to the Community. Your replacement has the firmware from when it was manufactured. The Charge 5 got additional clock faces with a firmware update. I suspect you will get those clock faces as you get the firmware updates you need.
Laurie | Maryland
09-26-2024 09:51
09-26-2024 09:51
Best Answer09-26-2024 10:26
09-26-2024 10:26
Hello @DocFaro
You are correct that there's nothing that you can do to force the Charge 5 firmware update to appear.
Best Answer09-26-2024 10:29
09-26-2024 10:29
09-28-2024 11:50
09-28-2024 11:50
You're welcome @DocFaro . I only wish I had better news for you.
