09-06-2024 14:32
09-06-2024 14:32
Anyone noticing a significant difference between app step count and device step count? App count is approximately 1,500 steps higher than what Charge 6 indicates. My husband's Charge 6 is doing the same thing.
09-06-2024 16:11
09-06-2024 16:11
I have the same issue.
Watch says 8500 steps and the app says 9500 steps.
D.
09-06-2024 18:58
09-06-2024 18:58
Is your app set to use the phone to record steps?
Best Answer09-06-2024 19:19
09-06-2024 19:19
I'm not sure I know what that means?
D.
Best Answer09-07-2024 19:01
09-07-2024 19:01
Do you have the app setup to count your steps?
Best Answer09-08-2024 03:31
09-08-2024 03:31
Best Answer09-10-2024 18:46
09-10-2024 18:46
I’m having a similar issue
Best Answer09-10-2024 18:51
09-10-2024 18:51
I believe I figured out why my step count was so high in the app. I had both my phone and my Fitbit Charge 6 counting my steps. I disconnected my phone from " connected to Fitbit" and the issue has been resolved.
D.
09-11-2024 15:00
09-11-2024 15:00
Same here! Just took pics… please help 🙏🏼
Best Answer09-12-2024 14:26
09-12-2024 14:26
Hello @lhammerman @KatieM1234
Have you had a chance to check to see if your phone is a connected device in the Fitbit app? If it's not, then your step count issue is likely related to the problem on the Fitbit side.
I saw a Moderator post today (12 Sep 2024) acknowledging the syncing issues and data transfer errors. He said that the team is working on identifying a resolution as quickly as possible.
For now, there's nothing more that we can do on our side.
