11-04-2025
18:18
06:59
DavidFitbit
11-04-2025
18:18
06:59
DavidFitbit
I would have deleted this post but I can't seem to figure out how to do that, just wanted to say that I did delete the app from my old phone and now I was able to connect it so the point is now moot I wish I could figure out how to cancel this post but I can't.
Best AnswerWednesday - last edited Wednesday
Hi, @Moscreations , I am sure it will be helpful to other users to know that you have solved your issue.
For other users experiencing this issue, in order to set up your Fitbit on a new phone, if you still have the old phone, you will need to disconnect the Fitbit from the Fitbit app on your old phone, as the OP did, and then connect the Fitbit to your new phone with the Fitbit app installed. You can also achieve the same result by making sure that Bluetooth is disconnected on your old phone in order to connect your Fitbit to your new phone.
Remember that your Fitbit (just like other Bluetooth devices can only be connected to one device. When it is connected to your old phone it will always be unable to sync to your new phone. And visa versa.
If you continue occasionally to use your old phone (for whatever reason) you should also delete the Fitbit app from your old phone so that it does not try to connect with your fitbit and cause connection issues with your new phone.
This issue should not arise if you no longer have the old phone or if it is turned off or permanently out of range.
Best Answer11-05-2025 07:45 - edited 11-05-2025 09:41
Hi @Moscreations, Thanks for stopping by, I hope you're doing well.
I'm glad to know that you have figured out how to sync your Charge 6 on your new phone Samsung S25.
I would like to clarify that you may be able to sync your Charge 6 to a new mobile by just turning off the Bluetooth of the old mobile device. This procedure is less invasive if you still want to sync your Fitbit to you old mobile.
On the other hand, the threads are meant to help as many users as possible when they are experiencing siilar issues. However, users can delete their messages by a request to a moderator. Do you still want to delete this thread ?
Best Answer11-05-2025 08:42
11-05-2025 08:42
If you think that what I wrote may help someone else then you can leave it, if not you can delete it
Thanks for the response
Wednesday
Thanks. And yes I did uninstalled the app. So all is good now 😀
