10-23-2024 09:05
10-23-2024 09:05
My Charge 6 stopped syncing this morning. It has always synced just fine and I had no problems until this morning. (As a note, I do not keep my Bluetooth on all the time. I usually turn it on and sync about three times a day.) I always sync first thing in the morning, and it just would not sync this morning. I went through all the troubleshooting steps multiple times, and still it would not sync. Finally decided to uninstall and reinstall the Fitbit app (which I really didn't want to do, knowing it would require re-pairing). To no great surprise, after reinstalling, it now won't pair either. When trying to get it to pair after the reinstall, it continues to give the same message: "There was an error while trying to bluetooth pair your device. Would you like to try again?"
I contacted support via chat, and the rep said that it's a known issue that the app is having difficulties with syncing data, etc. right now, and that they are working on it. But I feel like if it was really a widespread issue and no one could sync/pair today, then this forum would already have a lot more people complaining that they can't sync and the Fitbit Reddit sub would be blowing up as well. So I don't know what to think. Is anyone else having issues syncing today?
For reference, I have an Android phone... not sure if that matters.
11-01-2024 11:21
11-01-2024 11:21
11-01-2024 12:26
11-01-2024 13:00
11-01-2024 13:00
I tried again to pair my charge 6 with no luck. I went to phone settings, then apps, then fitbit. I tried to force stop and when it wouldn't let me, I Uninstaller fitbit. I downloaded and got 4.28.3 which was slow to setup but has worked fine for a couple of hours! I was able to keep all data!
11-01-2024 13:21
11-01-2024 13:21
I hit the update in the app store, but it seems it didn't update. Uninstalled and reloaded the 4.28.3 version and it finally pairs with my Charge and synced up. We will see if it continues but I am hopeful.
11-01-2024 13:24
11-01-2024 13:24
11-01-2024 13:34
11-01-2024 13:34
Well, well, got a fitbit update today and downloaded it and my charge 6 actually paired and synced up today. My wifes charge 4 also. Somebody at fitbit must have finally pulled their heads out of their backside and came up with a solution. Way beyond about time.
11-01-2024 14:10
11-01-2024 14:10
Yep... Worked for me, too! Too bad I had to find the solution on this forum instead of getting an update directly from Fitbit.
11-01-2024 14:35
11-01-2024 14:35
Best Answer11-01-2024 16:03
11-01-2024 16:03
Mine is working now. It took a little time to update after it paired, but it did finally do it.
11-01-2024 16:05
11-01-2024 16:05
working for me too
11-01-2024 17:50
11-01-2024 17:50
I am not syncing either...been 9 days.
Best Answer11-02-2024 02:19
11-02-2024 02:19
Uninstall the phone app and go to "Play Store2 and install the new version and it should work, it did for me.
11-02-2024 02:20
11-02-2024 02:20
"Play Store"
Best Answer11-02-2024 06:00
11-02-2024 06:00
Also having issues
Best Answer11-02-2024 06:02
11-02-2024 06:02
Best Answer11-03-2024 09:34 - edited 11-03-2024 09:34
Hi everybody ! Thank you for your updates and info .
I'm glad to read that the new app release helped with the syncing and pairing issue.
For those who are still having issues, please make sure that you have the latest app version installed.
Turn your phone off and on again.
Try to set up the Fitbit as a new device.
11-04-2024 13:44
11-05-2024 02:51
11-05-2024 02:51
I have had the same issues since a while (see my initial replies) and what I noticed is that every time I reinstalled the app, the sync worked again for a couple of days and then it stopped working again.
Now I just reinstalled it again - so removed the app first and then looked it up in the play store and reinstalled. Sync works again.
But I looked at the app details and it says '4.28.1.fitbit-mobile-110133271'. So I am wondering now whether the latest version is actually available for me to download ?
Nokia 6.1 - Android 10.
11-05-2024 06:15
11-05-2024 06:15
App updates are released to users in stages, keep checking and you will get it when it's your turn.
Gary D.| Feeding Hills, MA MBG PE
Pixel Watch 3, Pixel Watch 4
11-05-2024 10:14
11-05-2024 10:14
@gdio53 @RiekoC Thank you for your help .
@sedas , Nice to see you around. Thank you for your message and info.
As mentioned by @gdio53 the Fitbit app updates are released in stages, independently from your location. Meaning 2 users in the same household might get the updates available within a few days of difference.
In you case, I would ask you a bit of patience. Wait a few days or keep checking the play store for the updates every now and then.
Keep in mind that your Fitbit will contain the data from the last 7 days as a whole or the one from the last 30 days as a summary. This if you haven't restarted or deleted the info from the Fitbit.
Restarts might delete the info too.
