04-19-2025
15:29
09:43
LizzyFitbit
04-19-2025
15:29
09:43
LizzyFitbit
When I click steps, the day/week/month/year displays a spinning circle but never loads. Any help is appreciated!
11-10-2025 11:50
11-10-2025 11:50
Hello everyone!
I have excellent news. The fix for this bug is available in our iOS 4.56 Fitbit App. Please go to the Apple Store and update your app to this version.
Have a great day!
04-19-2025
19:26
11:37
AndreaFitbit
04-19-2025
19:26
11:37
AndreaFitbit
I'm having the same issue! It just started happening this afternoon. Logged out and logged back into the app, rebooted my phone, same issue. I did notice that under You and Goals, I see an error message "Something went wrong. Unable to load your goals". Maybe that's part of the issue?
Fixed it! Deleting and reinstalling the Fitbit iOS app on my iphone solved the issue.
04-19-2025 19:45
04-19-2025 19:45
04-20-2025 01:22
04-20-2025 01:22
Thank you! I had the same problem.
04-21-2025 07:03
04-21-2025 07:03
Thank you! Had the same problem.
04-24-2025 09:48
04-24-2025 09:48
Hi everyone, and welcome to our new members.
Thanks for bringing this to my attention and sharing the steps that you've tried so far.
@Birgitta.2008 and @Maarten68, I'm glad @Bernadette62's advice worked for all of you and I appreciate the update. I hope you can keep crushing your goals.
@MPruitt82 If you haven't done so, I also suggest trying to uninstall and then reinstall the Fitbit app as this has worked for other members. Once this is done, check if your goals are displaying correctly.
04-24-2025 12:48
04-24-2025 12:48
Thank you! I had the same issue.
04-24-2025 15:51
04-24-2025 15:51
Did deleting the app delete your data as well?
Best Answer04-24-2025 16:00 - edited 04-25-2025 09:15
No, once I reinstalled the app and signed in, all my data was there.
04-24-2025 17:30
04-24-2025 17:30
If deleting the app deletes your data, is there a way to recover the data?
Best Answer04-24-2025 17:36
04-24-2025 17:36
04-24-2025 17:43
04-24-2025 17:43
No, it did not. I logged into fitbit.com and saw all my data there. After deleting and reinstalling on my phone, all my data showed up.
04-24-2025 18:22
04-24-2025 18:22
Thanks to both of you for your responses!
04-24-2025 19:57
04-24-2025 19:57
04-24-2025 20:16
04-24-2025 20:16
My data came back too, no problem. This has been very helpful. Thanks again to all!
04-25-2025 11:32
04-25-2025 11:32
Hello @Dkt2299 , @lcurry720
As you discovered, deleting the Fitbit app on your mobile device won't delete your data. The app gets repopulated with your data when you log into your account and sync with your Fitbit. Your data gets uploaded to your account on the Fitbit servers when you do a sync.
Just an FYI. Fitbit devices typically store up to 7 days of tracked data.
The way you'd lose your tracked data on your Fitbit device is if you do a "factory data reset" and delete your data.
Best Answer04-27-2025 05:11
04-27-2025 05:11
Thank you! I had the same problem and it was driving me crazy!!
04-27-2025 06:57
04-27-2025 06:57
I reinstalled the app and the problem still there - I did not have a “delete” option per se
i clicked “remove this Charge 6”
is that the same thing as deleting?
04-27-2025 07:18
04-27-2025 07:18
04-27-2025 09:55
04-27-2025 09:55
Got it!!! I misinterpreted .... That worked
thank you!!
