10-25-2024
08:02
11:07
AndreaFitbit
10-25-2024
08:02
11:07
AndreaFitbit
I bought my Charge6 about 4 months ago to replace an ailing Charge2 (which had always been very reliable). 3 days ago it stopped syncing, having given a few problems with this over the last month or so. I tried restarting the device and re-installing the app on my phone, after deleting all previous Fitbit devices from Bluetooth settings. Now it won't pair with or set up the Charge6 at all and doesn't recognise it, despite me following all the instructions as if I was setting up a new device.
Help please!
Moderator Edit: Formatting.
Best Answer10-25-2024 10:34
10-25-2024 10:34
Hi there @mortoam welcome to the Fitbit Community! It's great to have you here. Allow me to help you with the syncing/pairing issues you are experiencing with your Charge 6.
If your device is no longer paired, you are attempting to set it up 3 and you find an error such as "Error Message or Missing PIN", follow the instructions below :
- Turn Bluetooth Off on your phone and then back On and retry Pairing.
- If Pairing still doesn't work, i recommend restarting your mobile device, your Charge 6 and try again
I hope this tips will help you!
Best Answer10-25-2024 10:48 - edited 10-25-2024 10:48
Hello @mortoam
From the posts I've read, there is a known issue that affects syncing with the app for Android users. It seems that the problem started around the time the users updated their Fitbit app to version 4.28. See this thread (<-- click link)
The team is aware of the issue and has been working on fixing the problem.
10-27-2024 09:10
10-27-2024 09:10
Any ETA on the fix?
Best Answer10-27-2024 09:26
10-27-2024 09:26
Hi David. Thanks for the advice. I've tried your suggestions but still have the problem. Andy
Best Answer10-27-2024 09:27
10-27-2024 09:27
No joy yet. If there's a known issue I may just have to wait until Fitbit issue a new fix...
Best Answer10-27-2024 09:29
10-27-2024 09:29
Thanks for the info. I'll wait to see if Fitbit announced a fix,...
Best Answer10-27-2024 11:13
10-27-2024 11:13
Why are you still advising all the tips when it is apparent that the App is the fault. Question is when is the App going to be fixed ?
Why haven`t google advised on this community?
10-27-2024 14:45
10-27-2024 14:45
There's an update for the Android app to version 4.28.1 that has started rolling out. According to some Moderator posts I read, it seems that this update was supposed to fix the syncing issue for Android users. Although it seems to have worked for some users, I've read multiple users posts stating that it didn't work.
Please let us know if you've already updated to version 4.28.1 and if that fixed the syncing issue for you.
Best Answer10-27-2024 17:31
10-27-2024 17:31
Updated to that new version and it did not fix the issue.
10-27-2024 22:54
10-27-2024 22:54
Nope still same 4.28.1 failed to rectify
10-28-2024 04:39
10-28-2024 04:39
10-28-2024 11:26
10-28-2024 11:26
Thank you for letting us know that updating to version 4.28.1 didn't fix the syncing issue.
From the user posts I've been reading, it seems this problem is affecting those with Samsung phones. Are you using a Samsung phone?
At this point, there isn't any troubleshooting that we can recommend since the synicing issue is on the Fitbit side.
Best Answer10-28-2024 11:37
10-28-2024 11:37
Thanks for reaching out to the Fitbit Customer Care Team.
For your reference, your case number is
We wanted to inform you about a recent update to the Fitbit app that addresses a bug causing syncing and pairing issues on Android devices.We’re here to help if you need any additional assistance with these steps or if you continue to experience any issues. Thank you for your patience and for being a valued Fitbit customer
We already added the information that your device is affected by the bug and the updates will be released quickly to you.
Thank you for your understanding
If you need more help, you can contact us again and reference this case number, or reply to this email to reopen your case.
Hi
I have spent ages on this issue
4.28.1 update issue not resolved
Android 14 latest notification, phone is up to date
Samsung A13
Nothing on fitbit due to advice given by many!!!
Data cleared update fails, phone finds fitbit unable to pair as no pin generated.
if you bothered to look at the Fitbit forum, you would see many failures due to the App
nothing wrong with our hardware.
4.28.1 is not the answer
regards
10-28-2024 12:07
10-28-2024 12:07
Hi. I'm using a Motorola phone.
Best Answer10-28-2024 12:13
10-28-2024 12:19
10-28-2024 12:19
So very frustrating. Phone says app is not installed, when it is. It won't pair, nothing works when every suggestion is tried. I can't even see what version is installed. Grrrr.
Best Answer10-28-2024 13:47
10-28-2024 13:47
Most of what I am reading relates to an A13 Samsung. I have the same phone, same issue. I have a Charge 6. Lost connection to the App on 22nd Oct. Spoke to a Google chap, said its a Fitbit App issue and is being worked on. They said 24 to 48 hours. It's still not working.
Best Answer10-28-2024 14:37
10-28-2024 14:37
Long press on the fitbit app 'info upper right scroll down you find the version 4.28.1 probably.
Best Answer10-28-2024 14:42
10-28-2024 14:42
Yes, it's running 4.28.1 already. I have uninstalled. Reinstalled. Restarted the device. I have done everything. Still does not work. Thanks.
