10-25-2025 19:16
10-25-2025 19:16
Fitbit charge 6 on charger all night but won't turn on. I've tried everything that has been suggested but there is nothing at all on the screen. It's only a few months old.
Best Answer10-26-2025 13:57
10-26-2025 13:57
Hello @JennyD13
If the troubleshooting suggested by the Moderator doesn't work, the next step would be to contact Support (<-- click). Complete the prompt in Step 1. Tap Continue in Step 2 (ignore Resources, you've already done that) to get to Step 3 which has the contact options. If Support determines that your device is defective, they will tell you what are your options under warranty.
10-26-2025 06:01
10-26-2025 06:01
Hi @JennyD13 and warm welcome to the Community.
I appreciate your message, and I'm sorry to hear that your Charge 6 is unresponsive. Thank you for the troubleshooting steps you tried.
Please let me suggest you some steps:
I also recommend you to take a look into the following help article, and apply these steps: Why isn't my Fitbit device's battery charging?
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
10-26-2025 13:57
10-26-2025 13:57
Hello @JennyD13
10-26-2025
23:50
13:11
AndreaFitbit
10-26-2025
23:50
13:11
AndreaFitbit
Thank you. That seems to have fixed the problem. It was fully charged so
don't know what happened.
Thank you if it happens again I'll contact them.
