09-09-2024
03:18
09:56
LizzyFitbit
09-09-2024
03:18
09:56
LizzyFitbit
Today suddenly my fitbit start to show the wrong time.
My time zone is Bangkok GMT+7:00 but the watch show the UTC time.(7 hours slower from my time zone)
I've try change to other location with GMT+7:00 in the setting but it still show the UTC time.
Meanwhile, I've tried Tokyo GMT+9:00 the time is shown correctly. (2 hours faster than my time zone)
Is there any way to fix this or is this somekind of bug?
Hi everyone, and a warm welcome to our new members.
Thanks for letting us know about the time on your Charge 6 and your efforts while working on this matter. I wanted to let you know that this has been escalated to our team, and it should be resolved.
I appreciate your patience and if you continue seeing the wrong time, I'd suggest opening the Fitbit app and pulling down on the Today screen to force a sync.
So I'm not the only one.
I've tried other time zone and it show the correct time, but only time zone in some Asia country showing only UTC time.
I'm starting to suspect that there are some problem with time zone server in Asian region.
My fitbit also stopped having the correct time during my sleep. It shows 4 hours ahead but Im in GMT-4:00 and it is synced correctly and my phone shows the right time. It appears that the fitbit syncs to the timezone but shows wrong time anyways. Dumbwatch 😕
Exact same issue. Also Bangkok time, but showing UTC time instead. Already did everything on other older threads on how to resolve wrong time (even tried ridiculous things like changing clockface, etc.). Versa 2 (not Charge 6, but same problem as OP). Any resolution?
Hello! Am also from Singapore, and I am having the same problem! My Fitbit Charge 6 is showing 11:55 AM instead of 7:55 PM! I have ensured the location and time settings are set to Singapore, uninstalled and re-installed the app, restarted my Fitbit watch countless of times but still no use! 😞
I just got this very same issue. I did not change time zones. It just happened.
I tried the regular fix.
Change time zone manually sync: time changed to something else
then set time zone to auto and sync again
Time changed to incorrect time again
Yes, same here! I am panicking!
Best AnswerSame issue with me as well, I am from India, watch is showing UTC time, I tried restarting, turning off auto detect location, and changing locations but nothing worked. Seems like this is an outrage. Good time to see how active the devs are for fitbit devices.
There was apparently an update on 6 Sep. I am not sure if that screwed up Charge 6's time display. 😭
