08-23-2016
04:37
20:15
08-23-2016
04:37
20:15
Hi,
The competitors have a feature called "Find my phone". It is a very simple thing and very usefull. If you lost your phone there should be an option "Find my phone" on the Fitbit wristbands that will enable a sound to your phone to easily find it.
Please implement it via firmware/software updates an all wristbands and smart watches!
08-23-2016 05:34
08-23-2016 05:34
That be wonderful @daniionescubv
Feel free to add your suggestions to the 'Feature Requests' Sub Forum, where users can vote, add comments,.. if there's a certain interest then there's a chance the developers pick it up and it'll be developed.
Important to prevent duplicates Search if the idea already has been suggested and add your vote / comment!
Feature Suggestions
Click here to add new suggestion
08-23-2016 05:34
08-23-2016 05:34
Feature Suggestions
12-30-2017 20:55
12-30-2017 20:55
I definitely second and agree with the suggestion of adding this feature of the Fitbit to be able to find your phone!!
I have the Fitbit Alta HR, and I am constantly losing my phone and usually have the volume turned off since I take a lot of pictures with it.
My husband has the Garmin Vivosport and it can find his phone. I really, really, really wish my Fitbit could do the same. Please, please add this feature!
I am actually even thinking about switching to a Garmin with this feature if Fitbit does not implement it.
01-05-2018 13:53
01-05-2018 13:53
Hey, I actually made a work around.
If you set up switchr and then install the app on your phone you can actually make your own find phone button.
Get the IFTT app on your phone.
Set up a new applet.
Use the trigger webhook and the action call phone. Make sure you're using your own number.
Go to services on IFTT and go to webhook. Find your key.
In the fitbit app go to the switchr settings and add a new button.
Make the url:
https://maker.ifttt.com/trigger/{event}/with/key/{key}
Make sure you make the event the one you made and the key you got from webhook.
If you want, use switchr to make a button that turns volume to max.
Then you can call your phone from your watch.
You're welcome peasants.
01-05-2018 14:12
01-05-2018 14:12
01-06-2018 08:52
01-06-2018 08:52
Hi! I’m not tech savvy. I thought I followed your instructions correctly but I still can’t get the command to actually call my phone. Have you made a video tutorial for this on YouTube by chance?
01-06-2018 17:13
01-06-2018 17:13
One issue might be that your fitbit watch is not connected to wifi.
Try using the fitbit app to connect it to wifi so it can use the webhook.
I actually ran into this ussue in my yard and don't think there is a work around.
Still works around the house when wifi is properly configured though.
02-02-2018
12:01
11:47
FerdinandFitbit
02-02-2018
12:01
11:47
FerdinandFitbit
I see this is on the HR and Ionic fitbits, can't seem to delete this question though. Sorry.
Hi Hal_9000 I can't seem to get the switchr app installed on my fibit Charger 2. Do you by chance know how to do this? Also I have tried searching through youtube, do you have a video of how to do this?
Moderator edit: Merged replies
02-28-2018 00:38
02-28-2018 00:38
Set your fitbit up to control your music. If you can't find your phone turn on the tunes.
04-02-2018 05:01
04-02-2018 05:01
This saved me from loosing my phone like a month ago... sadly, with the new update it seems that you can’t start the music anymore, only control it once the phone is playing
06-09-2018 12:17
06-09-2018 12:17
Please add a Find My Phone app. I originally had a different watch for fitness and I'm getting used to the Fitbit Versa. I found the Find My Phone app extremely beneficial. I almost returned this watch because it didn't have that.
07-28-2018 08:37
07-28-2018 08:37
It says this has been resolved but I don't see the solution. I don't want to download another app that i wont use but have to manipulate to find my phone.
07-28-2018 13:36
07-28-2018 13:36
That’s not the point, I lost my phone while hiking and was able to find it cause I started the music from my fitbit, with the last update it’s not possible to start the music, it only allows control once you start playing on your phone. We need an app to play a sound on the phone by Bluetooth signal or at least allow to start playing music again like before.
Your suggestion is not relevant to the thread.
08-06-2018 11:07
08-06-2018 11:07
This is not a solution. At best, it's a deferment, at worst it's a brush off.
09-12-2018 10:34
09-12-2018 10:34
Totally looking forward for this essential feature as well.
09-12-2018 10:59
09-12-2018 10:59
09-13-2018 13:02
09-13-2018 13:02
This post was from 2016 and it's now 2018 and STILL no "Find My Phone" feature. I can live without GPS since I always have my phone with me and the upcoming Charge 3 seems like the best fitness tracker based on what I need (personally) BUT it would be even better if it had a "Find My Phone" feature because I keep forgetting where I placed it especially when I'm folding laundry 🙃
09-14-2018 17:40
09-14-2018 17:40
I am not tech savvy! Hopefully there will be a simple way soon. Lol
09-17-2018 11:46
09-17-2018 11:46
Hi everyone! Good to see you in the Community Forums! 🙂
I'm very happy to let you know that the Find My Phone feature is now under consideration as you can see on the Feature Suggestion here.
Keep in mind that this doesn't mean that it will be for sure implemented but that it's being analyzed and that there is a possibility that we can have something like this in a near future.
Let me know if you have any questions about this.
10-12-2018 12:22
10-12-2018 12:22
I am very sad about this missing function. Also about missing date on the screen. And the screen locks after 2 or 5 seconds. It is my first smart watch and the son's Xiaomi Amazfit Bit looks more comfortable option than mine...
