I've seen similar ideas/feedback noted for the Surge/Blaze and I'd love to see the same sort of thing for the Ionic, I also saw an idea to change the 'stop exercise' button to the (left) hand button on the Ionic which would too be good but would very much prefer a lock screen if possible 🙂
When I'm sometimes performing pushups, boxing, burpees or anything that causes my hand to bend, I've sometimes ended up pushing the bottom right hand button to 'pause' the workout and then sometimes ended up pushing multiple buttons during workouts to end it prematurely.
I'd love it if it were possible to disable the buttons during certain workouts or have some kind of lock screen, maybe even a long-button push option to only unlock the screen when holding one of the buttons for a few seconds etc. At the moment, it's just far too easy to accidentally click the right hand buttons which are tied to pausing/ending workouts.
An idea which would be great would be that my old android watch had, I could turn the screen on with a button although in order to interact any further, I would need to manually swipe away a lock screen (or you could set it up with a PIN each time) and then you'd be able to start/end/pause the workout.
Thanks a lot for reading, really hope this could be considered for a future firmware update
Moderator Edit: Clarified subject and updated label
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
