06-19-2021 12:31
06-19-2021 12:31
Can we get a more dedicated Alexa Fitbit? Bigger battery, specifically for Alexa, we should be getting 2 weeks of battery life by the ability to disable every sensor including GPS, and HR monitor, ability to adjust brightness and keep it at that level..Need a physical button back, and also, how about adding the ability to talk to Alexa one handed? Maybe shake your rest or rapid twist, or something so we can check the weather while biking for example.
also what about the ability to send text messages and make start phone calls with Alexa? I am pretty sure many people wojld want Alexa on their hand more than any other fitness sensor..
Best Answer06-19-2021 13:37
06-19-2021 13:37
It sounds to me what you need is to get after Amazon to make a small battery-powered Alexa device, rather than expecting an exercise tracker to be dedicated to that function. But that's just my thought.
