02-08-2021
05:11
17:48
LizzyFitbit
02-08-2021
05:11
17:48
LizzyFitbit
Hi,
I have bought Fitbit charge couple of month ago, I have made a huge mistake and registered to fitibit premium for the free trial.
Since then I can't cancel the membership, even after calling fitbit customer service no luck.
I haven't used any program or service of fitibit premium but still getting charged.
How can I cancel it?
Thanks,
Yaniv
Moderator Edit: Clarified subject and updated label
Best AnswerHi, @yanivbrb welcome to the community, go to the place you downloaded the Premium app from (Apple or Google) pull up the app and you should be offered the choice to cancel. You will continue to see the premium account until your billing period expires (in fact for a few days after that) at which time it should lockout. You could also go to your card account and cancel the SO/DD through which it is being paid.
I hope this helps.
Cheers
Gr4ndp4 | UK
Hi @Gr4ndp4
Thank you for your suggestions but unfortunately, I have already tried it and both options have failed.
I have called customer service for the second time and hopefully, this will be resolved this time.
It is a shame that a good product has such not effective customer support.
Thanks,
Yaniv
Hi @yanivbrb, welcome. It's nice to have a new member around. @Gr4ndp4, thanks for stopping by to help our members!
Thanks for taking the time to contact our Support team, as well for following the suggestions shared above. I'm sorry for the experience that you've had so far. As our friend @Gr4ndp4 mentioned, you should be able to cancel your subscription from the App Store or Google Play Store. If any any chance you don't see your subscription, please give a try to the following steps:
By the way, I've moved your post to the Fitbit Premium & Coach board to keep our forums organized.
Keep me posted.
