12-10-2020
07:00
17:17
SilviaFitbit
12-10-2020
07:00
17:17
SilviaFitbit
I am having an issue with my fitbit where when I go to do my mindfulness for the day it never tracks my heart rate.
Best Answer12-10-2020 23:57
12-10-2020 23:57
Thank you, my Fitbit inspire 2 now logs meditation sessions as before. However it doesn't show the change in pulse rate on a meditation as it did before. It just says that the pulse is not available, even though the rate is being displayed on the device and the app at that time, is this another bug?
Thank you
Sue
12-11-2020
17:23
06:14
12-11-2020
17:23
06:14
@Chaddles274 @soo345 Hi there. I moved your post to the main board, this to better assist you.
I appreciate the details mentioned. Please restart your Fitbit, make sure that it has the latest firmware version installed and check that the Fitbit app is up-to-date too.
Once performed this, confirm that you're doing this procedure to track your Mindfulness sessions:
Note: You can’t pause the session, but you can quit at any time by pressing the button (buttons on Inspire 2).
Let me know how it goes. I'll be around if you have any additional questions.
Best Answer12-13-2020 04:40
12-13-2020 04:40
Hi - I'm not sure how to follow your instructions as I don't know where the 'relax app' is am I looking at the app on my phone or at the fitbit? - On my I can click on an icon that opens mindfulness sessions but that doesn't take me to anywhere that allows me to calibrate. I have a fitbit inspire 2.
Thank you
Sue
Best Answer12-14-2020 08:37
12-14-2020 08:37
I've noticed that mine does not show the heart rate right away. If I go out and sync my device, then go into My Journey and the session the heart rate updates.
12-16-2020
12:52
06:14
12-16-2020
12:52
06:14
@soo345 Thank you for getting back. The Relax app will be found on your Inspire 2's apps, if you track a Mindfulness session without wearing your Fitbit Inspire 2, it won't track heart rate information.
@toadslayer Hi there. In order to see heart rate data on your Fitbit app after completing a Relax session, your Inspire 2 needs to sync. Glad to hear that once it synced, you received heart rate.
Best Answer12-16-2020 23:39
12-16-2020 23:39
Hello Silvia - I am wearing my Inspire 2 whilst doing the sessions - in fact if I go into My Journey section the following day as suggested by Toadslayer then the HR information is there. My issue is that I don't understand what you mean by Fitbit Apps and where I would find them so I can't do the process you suggested on Dec 11
12-17-2020 04:13
12-17-2020 04:13
I have an android phone. I use an app on the phone from Fitbit. What are you syncing your device to? A computer, tablet, or phone (android or iPhone)?
Best Answer12-17-2020 11:09
12-17-2020 11:09
@soo345 In order to access the apps on Inspire 2 please swipe down to scroll through the apps then find the Relax app which will have a hear icon and then follow the instructions mentioned above.
@toadslayer Thanks for your input.
Best Answer01-03-2021 09:21
01-03-2021 09:21
My heartrate does not record after completing a mindfulness session, chosen in my fitbit app on my phone. I get a message saying no heartrate was recorded, please wear my fitbit. I was wearing my fitbit. I am using a Versa 3. I followed your instructions, and my heartrate recorded using the Relax app. But that's not the solution to what I was looking for. Why does it not record when using a mindfulness app (that I am paying extra money for in Premium)? The recent programs I have selected were over 10 minutes, so it's not that it didn't have enough time.
Thank you.
01-05-2021 04:56
01-05-2021 04:56
Same! I have an Android + Ionic. Relax app isn't the same thing as the premium mindfulness app with the Fitbit app. Relax, sure, HR captured & logged. Mindfulness, nope. Same message, after a session, it tells me to wear my Fitbit to track my HR, even though I am.
01-06-2021
11:37
06:13
01-06-2021
11:37
06:13
@SharyS @H3Dakota Hi there. Thanks for the details mentioned.
Keep in mind that to see details about your session, including your heart rate during the session, tap the Mindfulness tile. In the Fitbit app, then tap Your Journey. Please confirm you're doing this procedure to track your Mindfulness session:
Best Answer01-06-2021 15:39
01-06-2021 15:39
That's exactly what I've been doing, and it records that I've done a session, but says no heartrate was recorded and tells me to wear my fitbit. I wear my fitbit.
01-06-2021 16:45
01-06-2021 16:45
Same here. I get the message stating I need to wear my Fitbit to record my heartrate. Later, sometimes when I go back into My Journey, the heartrate mysteriously shows up. Sometimes not.
01-06-2021 18:43
01-06-2021 18:43
@SilviaFitbit @H3Dakota, my heartrate has never shown up when I go into My Journey. Only when I tried it through the Relax app.
Best Answer01-07-2021 04:39
01-07-2021 04:39
01-07-2021 08:11
01-07-2021 08:11
@H3Dakota You are right! That made the heartrate data show up. Thank you!
01-07-2021
11:37
06:13
01-07-2021
11:37
06:13
@SharyS @H3Dakota Thank you for the details mentioned.
Please try logging out from the app, force quit it, if you have and Android device clear cache. Also make sure that your phone OS and your Fitbit device firmware version is up-to-date. Once you've checked this, try recording another Mindfulness session.
Best Answer01-07-2021 12:40
01-07-2021 12:40
@SilviaFitbit , thanks, that worked!
Best Answer01-07-2021 14:14
01-07-2021 14:14
@H3Dakota that worked for me too! Thank you so much! I've only had my Inspire 2 a few weeks. Early on, there were some sessions where I still don't have a heart rate, but maybe I wasn't wearing the device correctly. All my recent sessions now have heart rate data. Thanks again!
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
