08-09-2020 07:02
08-09-2020 07:02
Logout function is missing from dashboard and replaced by profile. Have to go to activities to be able to logout. Also now you have to click on dashboard several times to get to the main page when starting the program.
08-10-2020 21:06
08-10-2020 21:06
Click on the gear upper corner and Logout is there
Wendy | CA | Moto G6 Android
08-11-2020 06:21
08-11-2020 06:21
Thanks Wendy, but there is no longer a gear icon on my dashboard unless I go to an activity. Having used Fit Bits for seven years I know all it's normal and abnormal problems and this is new and abnormal.
08-12-2020 17:24
08-12-2020 17:24
@KOM6420tm Welcome to the Fitbit Community. Thanks for letting us know that you've been a Fitbit user for seven years.
It's pretty weird that you're not seeing the Log out option in the gear icon. The website design hasn't changed, please cleared cookies and cache and try logging out again.
If you're still not seeing this option, please attach a screenshot of the options that you get when you click on your profile.
I'll be around if you have any additional questions.
08-12-2020 20:12 - last edited on 08-13-2020 17:14 by SilviaFitbit
-- The entire gear icon is missing from the Dashboard. In order to
logout I have to click "Dashboard" twice (which is also new). Then click
on "Log", click on "activities" and that is the first time I see the
gear icon with the normal selections including "Logout" I'll send a
screenshot tomorrow. I will also try clearing the browser cache.
___________________________________________________________
*Ted Mansfield
Moderator Edit: Personal info removed
08-13-2020 07:17
08-13-2020 07:17
Can't reply with video. Fit Bit support sucks.
08-13-2020 17:23
08-13-2020 17:23
@KOM6420tm Thanks for getting back. Sorry to hear that the "Logout" button is still missing.
I would like you to make sure you're following this procedure to attach a screenshot. Which browser are you using? Have you tried using another browser? Also, please make sure that the zoom of your screen is set to 100% and not more.
Looking forward to hearing back from you.
08-19-2020 08:43
08-19-2020 08:43
Hello @KOM6420tm,
Please note that you're on the Fitbit.com dashboard part of the forum, so any posts in this section are assumed to be based on how the dashboard looks like in the website, NOT the Fitbit app on your phone (I've seen people confuse the two). So this is what I'm seeing:
To me, it looks like this:
If this is not what you're seeing, post a screenshot of what you're seeing. All you need to do is to press Ctrl-PrtScn while on the dashboard and then Ctrl-V while posting.
I did the above by just using Snipping Tool and Paint; both which are installed on Windows.
I've seen the website occasionally get into a confused state and opening the Fitbit.com website on a new browser tab seems to get it working correctly again. I would try that as well.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
