I found this in the manual:
"If your battery is low, when you check your goal progress on your Flex 2, you’ll see a
flashing red light after you see your goal progress. You can also check your battery level on your Fitbit dashboard.
To charge your tracker:
1. Plug the charging cable into the USB port on your computer or a UL-certified
USB wall charger.
2. Press the tracker into the compartment on the charging cable The pins on the
charging cable must align with the corresponding pins on the back of the
tracker and lock securely in place. You’ll know the connection is secure when
the tracker vibrates and you see the indicator lights blinking, indicating your
progress towards a total charge"
Is this the information you were looking for?
USB wall charger.
