04-14-2017
20:47
17:15
04-14-2017
20:47
17:15
Help! All my Flex2 is doing is blinking...how do I fix it?
04-15-2017 01:36
04-15-2017 01:36
Hi. Try restarting it - that should fix it. Let us know how you go.
RESTART PROCEEDURE
Put your tracker into the charger so it has the charging lights showing. Then press the small button on the back of the charger 3 times within 5 seconds. It will vibrate with each press and then when all three are done it will very briefly flash all lights and then go back to charging lights and it is all done
Full instructions
http://help.fitbit.com/articles/en_US/Help_article/1186
Helen | Western Australia
04-15-2017 05:28
04-15-2017 05:28
When I press reset, there is no vibrating and it's still just blinking.
04-15-2017 06:24
04-15-2017 06:24
Did you press three times within 30 seconds? If that didnt work, do the complete restart three times in a row. If that doesnt work then you had better contact customer support. Let us know how you go.
11-16-2017 21:30
11-16-2017 21:30
How did this go as we have same problem now.
11-16-2017 21:39
11-16-2017 21:39
11-16-2017 22:12
11-16-2017 22:12
02-24-2018 07:04
02-24-2018 07:04
This does not work.
02-24-2018 07:06
02-24-2018 07:06
My Flex2 is blinking and it will not restart.
02-24-2018 16:53
02-24-2018 16:53
Then you need to contact Customer support (link in my signature )
01-14-2019 16:32
01-14-2019 16:32
Melissa ,
Was your fitbit flex 2 still under warranty?because mine is a year old in September and they wont replace it. Im so angry and its doing what yours is doing.
Monique
01-15-2019 02:44
01-15-2019 02:44
If the tracker is no longer under warranty then Fitbit wont replce it, which seems fair enough to me.
01-20-2019 09:15 - edited 01-20-2019 09:20
No its not fair of its a manufacturer issue as i believe this is. No worries because I went to Michael Kors smart watch. 2 year warranty and lifetime manufacturer's issues.
I have had 4 fitbits and my 2 newest which is the versa and flex 2 have been nothing but a problem. But it's ok.
This customer here is gone.
